Node Suspension
Don’t mess with the beta tag unless there is an announcement for the same in forum and/or emails. Also you aren’t stuck, your node auto updates if you have watchtower. See documentation for setting up watchtower. documentation.storj.io
This is not an error. Your node may have lost the race for the piece or it failed to receive acknowledgement for that piece in timely manner due to which it has “context canceled”. Its normal behavior. Check your log for GET_AUDIT and failed entries it will show the error.
Its better if you redirect your log to a file so you can diagnose any issues since logs are destroyed when you restart docker.
Thank you for understanding but you are a fellow SNO and this SNO family takes care of its own :slight_smile: We are here to help to the best of our ability.
Hi!
Could you also check my node?
1uBhTpXG5P75kVzEKcRMAernJbr4uELMwogxKDS8QQmBpEzUUQ
Thanks!
The satellite (asia-east) that suspended it has 99.8% successful uptime checks and 99.3% successful audit checks. It seems that the node is collecting data overall, but it’s showing 0 disk space usage by the satellite as of April 23.
P.S. my node has used 2.11TB of bandwidth and I believe during the initial configuration I set the 2TB bandwidth parameter. Could that affect my node and make satellites suspend it?
Here is my log (I do not understand why the upload was cancelled multiple times)
2020-04-23T01:13:50.925-0500 INFO piecestore uploaded {“Piece ID”: “5S33GWTCKHNQI2N7W35ST34CB37LTLCTZEGCUZTXONJG6BAK7WEA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:13:51.015-0500 INFO piecestore upload canceled {“Piece ID”: “5RGYUNSNXCODWHSLN4EBGHYRKVPLYKPWTK7MQFTKFZMO26YOFQTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:51.127-0500 INFO piecestore upload canceled {“Piece ID”: “6IN3PTYX7NOPACPXNABNQOM2NGN2LWBGBPQZ3HDJ6IAWP2XCE2NQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:51.189-0500 INFO piecestore uploaded {“Piece ID”: “MJZOPXQ3IISUR7HAREBZ5MF5JECAU7DZDUO6R2W6MITLOOPFZBTQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”}
2020-04-23T01:13:51.368-0500 INFO piecestore uploaded {“Piece ID”: “WRLM77NKL2AK4QUVPQYGB3GIKBV7OUXFEIRGP67D2BGD6AMFD5BA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:13:51.466-0500 INFO piecestore upload started {“Piece ID”: “N6LSREPBDNIAYCEU3MCYQW6WSMIKKR6FSYIDE4TPRO6LDJDVEXNQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025715045760}
2020-04-23T01:13:51.513-0500 INFO piecestore upload canceled {“Piece ID”: “HQQDZ5QS62LSAIWUYOL6YYFEHLSQW2GFCFYIJQYMTDAXWCDWSHZA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:51.577-0500 INFO piecestore uploaded {“Piece ID”: “KY5NZT6CLMGADBLC4PPV6YEY2BAHEHCM5BXMZRV5COFU57QRXQNQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:13:51.683-0500 INFO piecestore uploaded {“Piece ID”: “LCNVANGW4XL23F7RKHKUKNT7DPYAL2O6EEFC7CELNTCJEYNVQIVA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:13:51.895-0500 INFO piecestore upload canceled {“Piece ID”: “UUMLGXDJUC4YCAILZ2IXJQXVWUPLHLB6UUM522SGHHKLCEOEJUNA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:51.936-0500 INFO piecestore upload canceled {“Piece ID”: “TIJGRJCFALBKV5HROWNDYHSV272AJYZEPZLZLSJPP2WSFRCGOSZA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:52.084-0500 INFO piecestore uploaded {“Piece ID”: “2C6CSFT4BC25IJJYASLZFEXN3UKOPWLYTHTURHCCSHSNHJYBJYBA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:13:52.229-0500 INFO piecestore upload started {“Piece ID”: “B3LRDJWS5HZ4TKJZ274LBV5SZSDMZGFRDKSAAZA4DM57J5Z25CRA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025714769536}
2020-04-23T01:13:52.393-0500 INFO piecestore upload canceled {“Piece ID”: “YAFWF4GNZ45DLGRB4WYT3N7ORJXQH3C4WJCLFU5JFIWBW2AP6GSQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:52.709-0500 INFO piecestore upload started {“Piece ID”: “22YAXQKCVQX7VEMRSC4JGVT45JD53QVE2RZUQR4UT2BDNOGOMRWQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 3025712449664}
2020-04-23T01:13:52.746-0500 INFO piecestore uploaded {“Piece ID”: “B7CDPGPVFO5PT3U2XG2PM6WMAL3CSS5OWMN3VXF3EQIGGKL2WNAQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”}
2020-04-23T01:13:52.862-0500 INFO piecestore upload canceled {“Piece ID”: “54L2T47P2HSTP6U52PLZUZPUHMHGLJUR7TEBDHS6CG5FIZFS3B7A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:55.124-0500 INFO piecestore upload started {“Piece ID”: “BKE3DCY44BCPNY7P4U6MPBCUBZBBNY4VISF4CUPWUJ2G5OU3DBDQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025709980800}
2020-04-23T01:13:58.718-0500 INFO piecestore upload canceled {“Piece ID”: “QP2QCCW76L5Q3Y446SJCVHARBK4Z2Y76RI5HAHIXQ3L4FQEI5QPQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:58.719-0500 INFO piecestore upload canceled {“Piece ID”: “BWLDJ5GNTOOIUP76J3RZQQ44HJV75XIHWHB2K5CDBHTHAY7G5RLQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:13:59.018-0500 INFO piecestore upload started {“Piece ID”: “4ZAE3RGN2CDH4IBP373EQMQ74GL3XNHSBQACA4GKUNHUR2U5XMBQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT_REPAIR”, “Available Space”: 3025695015808}
2020-04-23T01:13:59.051-0500 INFO piecestore upload started {“Piece ID”: “GCB6JSTO3JHZXPDMV66J75QOEJVIN3SWF7UKQMBGOUVWTWY4GCPA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 3025695015808}
2020-04-23T01:14:00.326-0500 INFO piecestore upload started {“Piece ID”: “DNWQN7A75U32GMY6QHKVEMN6SGN4KHHTZH5VNO5YTD3QLZZQDSIA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025695015808}
2020-04-23T01:14:00.706-0500 INFO piecestore uploaded {“Piece ID”: “2EZCTE2AEMR7ZG5LYNBLPFX2VGRJVB4JPCCKV2MYV2DKJUXAW55A”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:14:00.706-0500 INFO piecestore deleted {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Piece ID”: “MDLRHQL6BC5ACT77IFOHNKK4HLICNGXPOYP24NXNX24IVCL3JE5Q”}
2020-04-23T01:14:00.979-0500 INFO piecestore upload canceled {“Piece ID”: “22YAXQKCVQX7VEMRSC4JGVT45JD53QVE2RZUQR4UT2BDNOGOMRWQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:01.101-0500 INFO piecestore upload canceled {“Piece ID”: “LSQ7QQWPSA4LXYX2N2GQHOWIIAXMP3ZAHS2WQ2KLXB3RWOP3NKZA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:01.577-0500 INFO piecestore upload canceled {“Piece ID”: “D3JFEHU5JA6KU5BMC2GPPE3ULVWRXQK6WFPYWI6OHXUCLZCAVIDQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:01.691-0500 INFO piecestore upload canceled {“Piece ID”: “B3LRDJWS5HZ4TKJZ274LBV5SZSDMZGFRDKSAAZA4DM57J5Z25CRA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:01.794-0500 INFO piecestore upload canceled {“Piece ID”: “V6NL4B4JDAL2WQNGPADFGEG5HJNVUZCEE6U3GUTLD6IHW3ZMGY6A”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:01.845-0500 INFO piecestore upload started {“Piece ID”: “5CDKK334VHI5TNPUCB4CBSQGO3ZK7CVK3C5ZYB65A7XFUTKOZGYQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025692695936}
2020-04-23T01:14:01.852-0500 INFO piecestore uploaded {“Piece ID”: “R7OJNGZWEVSPSLB3RFL2OSFQ76EWDCJUWN3OQ4HKMNJPYPIN62UA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:14:01.968-0500 INFO piecestore uploaded {“Piece ID”: “N6LSREPBDNIAYCEU3MCYQW6WSMIKKR6FSYIDE4TPRO6LDJDVEXNQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T01:14:02.132-0500 INFO piecestore upload canceled {“Piece ID”: “XJNLAQNQDJQ2JC336WH3HSU72UPUIM624S55UFNFOJ7PHM3TUQKA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:02.745-0500 INFO piecestore upload canceled {“Piece ID”: “URHDTPTSDIN3APQGZQQARURZLGK4TCEZQZ2NR6SRQ6QJOHY6EG7Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:02.768-0500 INFO piecestore upload started {“Piece ID”: “KOAF4SUZS34KHG3GYBATAYKQ4AQUVAQ5EI2XQXKF7SKVBM3W3WIA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 3025692695936}
2020-04-23T01:14:02.921-0500 INFO piecestore upload canceled {“Piece ID”: “BKE3DCY44BCPNY7P4U6MPBCUBZBBNY4VISF4CUPWUJ2G5OU3DBDQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T01:14:03.505-0500 INFO piecestore upload started {“Piece ID”: “EQZJIXTTVXAFYHQJ5WGO37E5QVZR2KSPOMAXNR6647XCS2YQZQ7Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025692695936}
2020-04-23T01:14:03.693-0500 INFO piecestore upload started {“Piece ID”: “RBKTSOQ742EKDXEMYHNKGIKMIC4424B2HOBRA42ED3LK4QWJF7WQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025692695936}
2020-04-23T01:14:03.783-0500 INFO piecestore upload started {“Piece ID”: “75LVN4OXLCV3AV3J4C6I4WQ6SBH4J3BHERKVKY46NKKSSAM2MXVQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 3025690376064}
PS C:\Users\User>
Suspended on both Asia-east-1 and us-central-1. No problems till those emails Been running non stop no problem.
Welcome to the forum @Lioqi!
Did you check your logs for errors like others did in this post ?
Could you help me with my case? I have attached the logs in my previous commentary to this post.
Thanks!
This is normal behavior. It means your node lost the race or failed to get acknowledgement for uploaded file. Nothing is wrong with such INFO messages. You need to find out error messages. Try searching for failed and GET_AUDIT log entry in your log it will show you the error.
Your Node is Suspended
Node ID:
1bbPmfwPvYzMVYykuaHwpAbcHFxizhXRAPYiu1pFBDphdNqEyF
Your Storage Node on the asia-east-1 Satellite was suspended. You were suspended on 2020-04-23 at 04:59 UTC.
Node ID:
Your Storage Node on the us-central-1 Satellite was suspended. You were suspended on 2020-04-23 at 04:49 UTC.
PS C:\Program Files\Storj\Storage Node> ls
    Каталог: C:\Program Files\Storj\Storage Node
Mode                LastWriteTime         Length Name
-a----       10.02.2020     13:53           6791 config — копия.yaml
-a----       10.04.2020     13:27           6792 config.yaml
-a----       23.04.2020     10:15          32768 revocations.db
-a----       07.04.2020     22:59       17355248 storagenode-updater.exe
-a----       22.04.2020     12:22        2887477 storagenode-updater.log
-a----       02.04.2020     15:23       17549808 storagenode-updater.old.exe
-a----       07.04.2020     22:59       24700400 storagenode.exe
-a----       23.04.2020     10:36     1136305991 storagenode.log
-a----       31.03.2020      0:08       24788464 storagenode.old.v1.0.1.exe
-a----       23.04.2020     10:15           1430 trust-cache.json
PS C:\Program Files\Storj\Storage Node> sls "GET_AUDIT" "C:\Program Files\Storj3\Storage Node\storagenode.log" | sls "failed"
Critically failed:	0
Critical Fail Rate:	0,00%
Recoverable failed:	0
Recoverable Fail Rate:	0,00%
Successful:		4476
Success Rate:		100,00%
Что не так с нодой? Лог за последние две недели.
Hello,
for info:
my node was suspended on EU-West (2020-04-23 at 07:09 UTC) and ASIA(2020-04-22 at 23:00 UTC) but I still receive uploads from this satellites.
EU was suspended one minute after i restart my node “docker restart -t 300 storagenode”
synology DS918+ 3x WD RED PRO 8TB connected internal sata
storj use 8,5 TB, alocated 11TB
RAM 4GB
storagenode run in docker container
NET: 300/20 Mbps
I have a similar problem with my node 1F4dnzimiErEE5diN7PyvUGZY7hpVMcDq74XnaAeY6KvB5Yp2f on us-central-1 and asia-east-1 since this morning. I also restarted my node. Could you please implement an alert email once suspension is lifted? This makes me feel realy uneasy when I can not be sure I won’t get qualified soon…
By the way I could not find any ERRORS with GET_AUDIT in my logs. The only errors I found where related to locked databases. Since I am running my node on a Synology DS918+ with internal drives in SHR-1 configuration I am not sure what I can do about that…
These are the errors that I get - “database is locked” and “connection forcibly closed by the remote host”
2020-04-23T03:05:29.588-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:30.803-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:30.920-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:31.085-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:31.271-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:31.350-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:32.143-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:33.225-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:35.218-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:35.603-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:35.981-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:36.124-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:36.378-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:36.628-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:674\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:37.579-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:39.021-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:39.755-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:41.302-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:42.486-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:42.854-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:42.988-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:44.334-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:674\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:44.676-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:45.728-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:46.170-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:47.946-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:48.191-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:48.237-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:49.820-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:50.094-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:50.599-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload.func5:346\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:362\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:51.566-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:51.668-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:52.064-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:05:52.226-0500 ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T03:06:10.854-0500 ERROR piecestore download failed {“Piece ID”: “JECPQEJQ3KJQQER2F4QOUNKWJNPTVLCLJ35BXPRIPKVMFWFVLC7Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”, “error”: “write tcp 192.168.1.4:28967->95.217.155.7:61170: wsasend: An existing connection was forcibly closed by the remote host.”, “errorVerbose”: “write tcp 192.168.1.4:28967->95.217.155.7:61170: wsasend: An existing connection was forcibly closed by the remote host.\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:221\n\tstorj.io/drpc/drpcwire.SplitN:29\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:276\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:318\n\tstorj.io/common/pb.(*drpcPiecestoreDownloadStream).Send:1080\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5.1:633\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22”}
2020-04-23T03:10:26.133-0500 ERROR piecestore download failed {“Piece ID”: “A7BR3HA3GGQQDSOAENJAJ7NWUR6MHJ6ALP5R7N32WZ6O5H5EWWKQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”, “error”: “write tcp 192.168.1.4:28967->95.217.184.115:8660: wsasend: An existing connection was forcibly closed by the remote host.”, “errorVerbose”: “write tcp 192.168.1.4:28967->95.217.184.115:8660: wsasend: An existing connection was forcibly closed by the remote host.\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:221\n\tstorj.io/drpc/drpcwire.SplitN:29\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:276\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:318\n\tstorj.io/common/pb.(*drpcPiecestoreDownloadStream).Send:1080\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5.1:633\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22”}
2020-04-23T03:23:39.927-0500 ERROR piecestore download failed {“Piece ID”: “QCFO7M6JHI37SDDFBGDZSUUBSOCLG7B7APOIRMUHTF7M2OTXTLEA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”, “error”: “write tcp 192.168.1.4:28967->95.217.186.82:13730: wsasend: An existing connection was forcibly closed by the remote host.”, “errorVerbose”: “write tcp 192.168.1.4:28967->95.217.186.82:13730: wsasend: An existing connection was forcibly closed by the remote host.\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:221\n\tstorj.io/drpc/drpcwire.SplitN:29\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:276\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:318\n\tstorj.io/common/pb.(*drpcPiecestoreDownloadStream).Send:1080\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5.1:633\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22”}
PS C:\Users\User>
Upon looking a little closer around the timestamps I found this on my node 1F4dnzimiErEE5diN7PyvUGZY7hpVMcDq74XnaAeY6KvB5Yp2f:
Your Storage Node on the asia-east-1 Satellite was suspended. You were suspended on 2020-04-23 at 06:06 UTC.
2020-04-23T06:07:02.105Z	ERROR	piecestore	download failed	{"Piece ID": "Z7WHX75FX7UKNW4HBRC4NJEBCPTYIO6OK2FXPS37TQZU5VRWAJDA", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Action": "GET", "error": "tls: use of closed connection", "errorVerbose": "tls: use of closed connection\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:221\n\tstorj.io/drpc/drpcwire.SplitN:29\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:276\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:318\n\tstorj.io/common/pb.(*drpcPiecestoreDownloadStream).Send:1080\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5.1:633\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2020-04-23T06:07:02.157Z	ERROR	piecestore	download failed	{"Piece ID": "EHEJDVLWZWALX5CWSLQE2EIWN7E52KI5EXAHLDIPSZP5UKXJIJRA", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "GET", "error": "tls: use of closed connection", "errorVerbose": "tls: use of closed connection\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:221\n\tstorj.io/drpc/drpcwire.SplitN:29\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:276\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:318\n\tstorj.io/common/pb.(*drpcPiecestoreDownloadStream).Send:1080\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5.1:633\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
But as far as I can see the errors occurred on transfers to other satellites…
Your Storage Node on the us-central-1 Satellite was suspended. You were suspended on 2020-04-23 at 01:02 UTC.
2020-04-23T01:02:31.770Z	ERROR	piecestore	failed to add bandwidth usage	{"error": "bandwidthdb error: database is locked", "errorVerbose": "bandwidthdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:59\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:721\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
Could you please help me what to do in order to avoid disqualification?
How is your HDD connected ?
It’s connected via USB. 3.5 / 5 TB free.
I have DB locked too, its usual at the order send time.
RAM 4GB
2020-04-23T07:30:49.081Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {“count”: 299}
2020-04-23T07:30:49.081Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {“count”: 79}
2020-04-23T07:30:49.081Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {“count”: 1117}
2020-04-23T07:30:49.082Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW sending {“count”: 340}
2020-04-23T07:30:49.082Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {“count”: 272}
2020-04-23T07:30:49.431Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2020-04-23T07:30:49.435Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW finished
2020-04-23T07:30:50.122Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2020-04-23T07:30:50.830Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2020-04-23T07:30:57.569Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE finished
2020-04-23T08:28:06.650Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:674\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:07.028Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:07.330Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:07.730Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:09.052Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:09.858Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:10.935Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:11.094Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:11.520Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:11.547Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:11.567Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:674\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:11.632Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:11.672Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:12.805Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:14.306Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:14.806Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:14.922Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:16.922Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:17.645Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:17.741Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:18.259Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:18.304Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:19.668Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:674\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:20.006Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:20.166Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:20.945Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:21.732Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:21.972Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:22.222Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:674\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:23.390Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:23.412Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func6:671\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:695\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:466\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:28:24.067Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T08:32:45.505Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {“count”: 11}
2020-04-23T08:32:45.505Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {“count”: 943}
2020-04-23T08:32:45.505Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW sending {“count”: 1219}
2020-04-23T08:32:45.505Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {“count”: 4501}
2020-04-23T08:32:45.505Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {“count”: 828}
2020-04-23T08:32:45.505Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {“count”: 156}
2020-04-23T08:32:45.855Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
2020-04-23T08:32:46.605Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2020-04-23T08:32:47.627Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW finished
2020-04-23T08:32:49.677Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2020-04-23T08:32:50.342Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2020-04-23T08:32:52.833Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE finished
2020-04-23T09:30:13.291Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {“count”: 13}
2020-04-23T09:30:13.291Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {“count”: 4481}
2020-04-23T09:30:13.291Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {“count”: 149}
2020-04-23T09:30:13.291Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW sending {“count”: 1236}
2020-04-23T09:30:13.291Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {“count”: 789}
2020-04-23T09:30:13.291Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {“count”: 876}
2020-04-23T09:30:13.536Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
2020-04-23T09:30:14.054Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2020-04-23T09:30:16.387Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW finished
2020-04-23T09:30:16.407Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2020-04-23T09:30:18.939Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2020-04-23T09:30:28.083Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE finished
2020-04-23T09:31:26.799Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T09:31:27.190Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T09:31:27.349Z ERROR piecestore failed to add order {“error”: “ordersdb error: database is locked”, “errorVerbose”: “ordersdb error: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).Enqueue:53\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).saveOrder:714\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:443\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
Can you find out the model of your HDDs ?
WD RED PRO 8TB
WD8003FFBX-68B9AN0
It’s WB Easystore 5TB.
I run a similar setup to yours:
DS918+
2x WD80EFAX-68KNBN0
1x WD80EFAX-68LHPN0
SHR-1
Also got the problem with database locked.
maybe too much read operation, but why ?
I only use media server (i dont index storagenode folder), cloud station server (i try to stop this two packages but no changes with disk utilization) docker with one storagenode, watchtower and storj-exporter (prometheus metrics)
maybe SHR is not good for storj ? I have 2 disks “raid 1” and add 3. and SHR recalculate to “raid 5” - in November
Having so many people with these problems, im starting to think the problem is on STORJ side not on ours…
Can somebody shed some light on it what is happening?
