Hi,
Since monday 13th at 17h00 UTC, my node is shut down and refuses to start.
My node (v1.56.4) is running on rpi 4 8GB (120 GB SSD), 12 TB HDD for storage and docker.
I haven’t done anything on it or the hardware or anything else.
I stopped and deleted the storagenode container but i get error to save trust.json and to contact satellite.
I try to change owner of my storj folder (the change stills happen) because now, there is the parameter : “–user $(id -u):$(id -g)”
I checked the ports :
- 14002 is open
- 28967 (tcp/udp) and 7777 are closed.
On my router, all ports are forwarded and open. I disable the firewall on the rpi.
I restarted several times the rpi, node, router but nothing is better.
Could a kind soul help me please ?
Regards
Log :
docker logs --tail 200 storagenode
6850K .......... .......... .......... .......... .......... 48% 14.5M 1s
14350K .......... .......... ... 100% 22.5M=1.2s
2022-06-15 18:15:45 (11.9 MB/s) - '/tmp/storagenode.zip' saved [14718174/14718174]
2022-06-15 18:15:46,698 INFO RPC interface 'supervisor' initialized
2022-06-15 18:15:46,700 INFO supervisord started with pid 1
2022-06-15 18:15:47,709 INFO spawned: 'processes-exit-eventlistener' with pid 56
2022-06-15 18:15:47,723 INFO spawned: 'storagenode' with pid 57
2022-06-15 18:15:47,737 INFO spawned: 'storagenode-updater' with pid 58
2022-06-15T18:15:47.855Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.level"}
2022-06-15T18:15:47.856Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.output"}
2022-06-15T18:15:47.856Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.stack"}
2022-06-15T18:15:47.856Z INFO Invalid configuration file value for key {"Process": "storagenode-updater", "Key": "log.development"}
2022-06-15T18:15:47.860Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.56.4"}
2022-06-15T18:15:47.861Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2022-06-15T18:15:47.939Z INFO Operator email {"Process": "storagenode", "Address": "my-email"}
2022-06-15T18:15:47.939Z INFO Operator wallet {"Process": "storagenode", "Address": "my-wallet"}
2022-06-15T18:15:48.325Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.56.4"}
2022-06-15T18:15:48.325Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2022-06-15T18:15:48.353Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.56.4"}
2022-06-15T18:15:48.353Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2022-06-15 18:15:49,355 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-06-15 18:15:49,355 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-06-15 18:15:49,356 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-06-15T18:15:49.368Z INFO Telemetry enabled {"Process": "storagenode", "instance ID": "1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A"}
2022-06-15T18:15:49.530Z INFO db.migration Database Version {"Process": "storagenode", "version": 53}
2022-06-15T18:16:08.440Z WARN trust Unable to save list cache {"Process": "storagenode", "error": "open config/trust-cache.json4069946084: permission denied", "errorVerbose": "open config/trust-cache.json4069946084: permission denied\n\tstorj.io/common/fpath.AtomicWriteFile:21\n\tstorj.io/storj/storagenode/trust.SaveCacheData:115\n\tstorj.io/storj/storagenode/trust.(*Cache).Save:72\n\tstorj.io/storj/storagenode/trust.(*List).saveCache:130\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:107\n\tstorj.io/storj/storagenode/trust.(*List).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:250\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:187\n\tstorj.io/storj/storagenode.(*Peer).Run:871\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:08.442Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"Process": "storagenode"}
2022-06-15T18:16:09.162Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"Process": "storagenode"}
2022-06-15T18:16:09.163Z INFO Node 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A started {"Process": "storagenode"}
2022-06-15T18:16:09.164Z INFO Public server started on [::]:7777 {"Process": "storagenode"}
2022-06-15T18:16:09.164Z INFO Private server started on 127.0.0.1:7778 {"Process": "storagenode"}
2022-06-15T18:16:09.164Z INFO failed to sufficiently increase receive buffer size (was: 176 kiB, wanted: 2048 kiB, got: 352 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details. {"Process": "storagenode"}
2022-06-15T18:16:14.242Z WARN contact:service failed PingMe request to satellite {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:19.461Z WARN contact:service failed PingMe request to satellite {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "error": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:24.808Z WARN contact:service failed PingMe request to satellite {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "error": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:30.322Z WARN contact:service failed PingMe request to satellite {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:35.643Z WARN contact:service failed PingMe request to satellite {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:41.453Z WARN contact:service failed PingMe request to satellite {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:41.454Z WARN failed QUIC check {"Process": "storagenode", "error": "ping satellite: failed to ping storage node using QUIC: ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to ping storage node using QUIC: ping satellite: check-in network: failed to ping node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address: my-url:28967, err: contact: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:176\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:845\n\tstorj.io/storj/storagenode.(*Peer).Run:884\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:479\n\truntime.main:255"}
2022-06-15T18:16:41.456Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "5h54m20.103175038s"}
2022-06-15T18:16:41.459Z INFO bandwidth Performing bandwidth usage rollups {"Process": "storagenode"}
2022-06-15T18:16:41.593Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:41.694Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:41.909Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:42.026Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:42.118Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:42.584Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:42.734Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-06-15T18:16:42.904Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 1VjbsodmwtNB8xNDbX2XeFQJtJjzTXBZXY1nCgejso3zQwGi9A) at address my-url:28967: rpc: tcp connector failed: rpc: dial tcp my-ip:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
