I am running windows and having problems wiht my node uptime getting reset - it provides an error in the even logs of The Storj V3 Storage Node service terminated unexpectedly.
When trying to look into it - I noted my node version reflects as v1.105.4 - which I found may just be it reporting the wrong version.
how do I check what version my nodes are actually running - is there a commany I can run from a powershell?
Yes, the dashboard says that when I hover over the version.
I do not understand that link.
I am trying to fix the issue and not wait, as the node is just getting more bad audits.
Your bad audits are unlikely related to that node version. However, a manual update could be done by stopping the service and replacing the storagenode.exe file.
