I’m new to storj dcs, is the nodejs uplink library or api still supported. I followed their Documentation and github repo.
when I try npm install uplink-nodejs I get warnings that the library is no longer supported and lot of errors.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See There’s Math.random(), and then there’s Math.random() · V8 for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm ERR! code 1
npm ERR! path /home/abhith/storj1/node_modules/uplink-nodejs
npm ERR! command failed
npm ERR! command sh /tmp/install-b34cdc16.sh
npm ERR! make: Entering directory ‘/home/abhith/storj1/node_modules/uplink-nodejs/build’
npm ERR! CXX(target) Release/obj.target/uplink/libUplink.o
npm ERR! make: Leaving directory ‘/home/abhith/storj1/node_modules/uplink-nodejs/build’
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@7.1.2
npm ERR! gyp info using node@16.17.1 | linux | x64
npm ERR! gyp info find Python using Python version 3.10.6 found at “/usr/bin/python3”
npm ERR! (node:19662) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
npm ERR! (Use node --trace-deprecation ... to show where the warning was created)
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args ‘/home/abhith/storj1/node_modules/node-gyp/gyp/gyp_main.py’,
npm ERR! gyp info spawn args ‘binding.gyp’,
npm ERR! gyp info spawn args ‘-f’,
npm ERR! gyp info spawn args ‘make’,
npm ERR! gyp info spawn args ‘-I’,
npm ERR! gyp info spawn args ‘/home/abhith/storj1/node_modules/uplink-nodejs/build/config.gypi’,
npm ERR! gyp info spawn args ‘/home/abhith/storj1/node_modules/node-gyp/addon.gypi’,
npm ERR! gyp info spawn args ‘/home/abhith/.cache/node-gyp/16.17.1/include/node/common.gypi’,
npm ERR! gyp info spawn args ‘-Dlibrary=shared_library’,
npm ERR! gyp info spawn args ‘-Dvisibility=default’,
npm ERR! gyp info spawn args ‘-Dnode_root_dir=/home/abhith/.cache/node-gyp/16.17.1’,
npm ERR! gyp info spawn args ‘-Dnode_gyp_dir=/home/abhith/storj1/node_modules/node-gyp’,
npm ERR! gyp info spawn args ‘-Dnode_lib_file=/home/abhith/.cache/node-gyp/16.17.1/<(target_arch)/node.lib’,
npm ERR! gyp info spawn args ‘-Dmodule_root_dir=/home/abhith/storj1/node_modules/uplink-nodejs’,
npm ERR! gyp info spawn args ‘-Dnode_engine=v8’,
npm ERR! gyp info spawn args ‘–depth=.’,
npm ERR! gyp info spawn args ‘–no-parallel’,
npm ERR! gyp info spawn args ‘–generator-output’,
npm ERR! gyp info spawn args ‘build’,
npm ERR! gyp info spawn args ‘-Goutput_dir=.’
npm ERR! gyp info spawn args ]
npm ERR! gyp info ok
npm ERR! (node:19679) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
npm ERR! In file included from …/functions/definitions.h:13,
npm ERR! from …/libUplink.h:5,
npm ERR! from …/libUplink.cc:6:
npm ERR! …/functions/…/libuplinkcversion.h:3:23: fatal error: …/libuplinkcv1.2.4.h: No such file or directory
npm ERR! 3 | #define UPLINKCHEADER “…/libuplinkcv1.2.4.h”
npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~
npm ERR! compilation terminated.
npm ERR! make: *** [uplink.target.mk:127: Release/obj.target/uplink/libUplink.o] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: make failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/home/abhith/storj1/node_modules/node-gyp/lib/build.js:194:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
npm ERR! gyp ERR! System Linux 5.15.0-52-generic
npm ERR! gyp ERR! command “/home/abhith/.nvm/versions/node/v16.17.1/bin/node” “/home/abhith/storj1/node_modules/.bin/node-gyp” “rebuild”
npm ERR! gyp ERR! cwd /home/abhith/storj1/node_modules/uplink-nodejs
npm ERR! gyp ERR! node -v v16.17.1
npm ERR! gyp ERR! node-gyp -v v7.1.2
npm ERR! gyp ERR! not ok
