Oops, something is definitely not right…
After going through the saved logs, I found a lot of errors happening. The logs are a bit extensive, so sorry for the log dump below:
026-08-13 00:13:10.909732+00:002026-08-13T00:13:10Z ERROR services unexpected shutdown of a runner {"process": "storagenode", "name": "piecestore:monitor", "error": "piecestore monitor: timed out after 1m0s while verifying writability of storage directory", "errorVerbose": "piecestore monitor: timed out after 1m0s while verifying writability of storage directory\n\tstorj.io/storj/storagenode/monitor.(*Service).verifyWritability:194\n\tstorj.io/common/sync2.(*Cycle).Run:163\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func2:124\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93"}
2026-08-13 00:13:10.909927+00:002026-08-13T00:13:10Z ERROR piecemigrate:chore failed to enqueue for migration {"process": "storagenode", "error": "couldn't list new pieces to migrate: filewalker: context canceled", "errorVerbose": "couldn't list new pieces to migrate: filewalker: context canceled\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).enqueueSatellite:338\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).runOnce:285\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).Run.func1:267\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).Run.(*Group).Go.func5:21\n\tsync.(*WaitGroup).Go.func1:258", "sat": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2026-08-13 00:13:10.949163+00:002026-08-13T00:13:10Z ERROR piecestore error sending hash and order limit {"process": "storagenode", "piece_id": "UOG7NDJUUUJ4KYFY7MAEBEC3AAMQ6CVMWLSGPISI4DJFTS727OPA", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "action": "GET_REPAIR", "offset": 0, "size": 3840, "remote_address": "45.137.206.117:52852", "error": "EOF"}
2026-08-13 00:13:10.956055+00:002026-08-13T00:13:10Z ERROR piecestore download failed {"process": "storagenode", "piece_id": "UOG7NDJUUUJ4KYFY7MAEBEC3AAMQ6CVMWLSGPISI4DJFTS727OPA", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "action": "GET_REPAIR", "offset": 0, "size": 3840, "remote_address": "45.137.206.117:52852", "error": "EOF", "errorVerbose": "EOF\n\tstorj.io/common/rpc/rpcstatus.NamedWrap:117\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:760\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2026-08-13 00:13:11.029327+00:002026-08-13T00:13:11Z INFO lazyfilewalker.used-space-filewalker subprocess exited with status {"process": "storagenode", "satellite_id": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "status": -1, "error": "signal: killed"}
2026-08-13 00:13:11.029484+00:002026-08-13T00:13:11Z ERROR pieces used-space-filewalker failed {"process": "storagenode", "satellite_id": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "lazy_file_walker": true, "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:134\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:781\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93"}
2026-08-13 00:13:11.034738+00:002026-08-13T00:13:11Z ERROR pieces used-space-filewalker failed {"process": "storagenode", "satellite_id": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "lazy_file_walker": false, "error": "filewalker: used_space_per_prefix_db: context canceled", "errorVerbose": "filewalker: used_space_per_prefix_db: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSpacePerPrefixDB).Get:81\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:163\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:150\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:790\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93"}
2026-08-13 00:13:11.034848+00:002026-08-13T00:13:11Z ERROR piecestore:cache encountered error while computing space used by satellite {"process": "storagenode", "error": "filewalker: used_space_per_prefix_db: context canceled", "errorVerbose": "filewalker: used_space_per_prefix_db: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSpacePerPrefixDB).Get:81\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:163\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:150\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:790\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93", "satellite_id": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2026-08-13 00:13:11.034914+00:002026-08-13T00:13:11Z INFO pieces used-space-filewalker started {"process": "storagenode", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2026-08-13 00:13:11.034958+00:002026-08-13T00:13:11Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2026-08-13 00:13:11.039393+00:002026-08-13T00:13:11Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"process": "storagenode", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
2026-08-13 00:13:11.039500+00:002026-08-13T00:13:11Z ERROR pieces used-space-filewalker failed {"process": "storagenode", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "lazy_file_walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:134\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:781\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93"}
2026-08-13 00:13:11.039578+00:002026-08-13T00:13:11Z ERROR pieces used-space-filewalker failed {"process": "storagenode", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "lazy_file_walker": false, "error": "filewalker: used_space_per_prefix_db: context canceled", "errorVerbose": "filewalker: used_space_per_prefix_db: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSpacePerPrefixDB).Get:81\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:163\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:150\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:790\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93"}
2026-08-13 00:13:11.039622+00:002026-08-13T00:13:11Z ERROR piecestore:cache encountered error while computing space used by satellite {"process": "storagenode", "error": "filewalker: used_space_per_prefix_db: context canceled", "errorVerbose": "filewalker: used_space_per_prefix_db: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSpacePerPrefixDB).Get:81\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:163\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:150\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:790\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2026-08-13 00:13:11.347959+00:002026-08-13T00:13:11Z ERROR piecestore:cache error getting current used space for trash: {"process": "storagenode", "error": "filestore error: failed to walk trash namespace 7b2de9d72c2e935f1918c058caaf8ed00f0581639008707317ff1bd000000000: context canceled", "errorVerbose": "filestore error: failed to walk trash namespace 7b2de9d72c2e935f1918c058caaf8ed00f0581639008707317ff1bd000000000: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).SpaceUsedForTrash:302\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:104\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93"}
2026-08-13 00:13:25.910693+00:002026-08-13T00:13:25Z WARN services service takes long to shutdown {"process": "storagenode", "name": "collector"}
2026-08-13 00:13:25.910791+00:002026-08-13T00:13:25Z WARN servers service takes long to shutdown {"process": "storagenode", "name": "server"}
2026-08-13 00:13:25.915212+00:002026-08-13T00:13:25Z WARN services service takes long to shutdown {"process": "storagenode", "name": "piecemigrate:chore"}
