Nodes gone offline and local host not opening
Myl ocalhost does not open anymore and I received emails saying that my node has gone offline.
What could I do to put it back online?
The computer still has access to internet so it is not a network pb
Please post the last 20 lines from your logs here between two new lines with three backticks, like this:
logs lines here
There is a lot of activity and I too had the same problem. I fixed it by restarting the server.
Yes, but it’s better to know, why is it stopped.
So when it stop again, please take the last 20 lines from the logs, they could point out what is wrong.
I already tried restarting before sending message.
if in cmd or powershell I enter
Get-Content “pathtologfile” -Tail 20 -Wait
it says
in cmd : ‘Get-Content’ is not recognized as an internal or external command,
operable program or batch file.
in poowershell
PS C:\Users\Hamza> Get-Content “pathtologfile” -Tail 20 -Wait
Get-Content : Cannot find path ‘C:\Users\Hamza\pathtologfile’ because it does not exist.
At line:1 char:1
  • Get-Content “pathtologfile” -Tail 20 -Wait
  •   + CategoryInfo          : ObjectNotFound: (C:\Users\Hamza\pathtologfile:String) [Get-Content], ItemNotFoundExcepti
     on
      + FullyQualifiedErrorId : PathNotFound,Microsoft.PowerShell.Commands.GetContentCommand
I looked at the storagenode updater and it seems there has been an update that caused the pb
2022-10-14T20:44:00.902-0400 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “storage.allocated-disk-space”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “contact.external-address”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “operator.wallet-features”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “storage.path”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “healthcheck.details”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “storage.allocated-bandwidth”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “operator.email”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “server.private-address”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “server.address”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “healthcheck.enabled”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file key {“Key”: “operator.wallet”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file value for key {“Key”: “log.output”}
2022-10-14T20:44:00.903-0400 INFO Invalid configuration file value for key {“Key”: “log.level”}
2022-10-14T20:44:00.903-0400 INFO Anonymized tracing enabled
2022-10-14T20:44:00.909-0400 INFO Running on version {“Service”: “storagenode-updater”, “Version”: “v1.64.1”}
2022-10-14T20:44:00.909-0400 INFO Downloading versions. {“Server Address”: “https://version.storj.io”}
2022-10-14T20:44:01.192-0400 INFO Current binary version {“Service”: “storagenode”, “Version”: “v1.64.1”}
2022-10-14T20:44:01.192-0400 INFO New version is being rolled out but hasn’t made it to this node yet {“Service”: “storagenode”}
since you use a Windows GUI node, you need to provide a correct path to your logs.
If you did not change the logs location, it is in the "C:\Program Files\Storj\Storage Node\storagenode.log" by default.
So use this command in the PowerShell:
Get-Content "C:\Program Files\Storj\Storage Node\storagenode.log" -Tail 20
You may ignore INFO messages from the updater, since it uses the same config.yaml as a storage node, it is just do not recognize parameters needed for the storage node.
I reverted to a previous restore point and the system is back
i am now suspended from eu1.storj.io:7777
at 95%, how long will it take to come back, it was down for 28hrs
This could be very bad if data has been lost. Did you find the log file entries as @Alexey was asking?
This is just the Suspension, not Audit score? What is the Online score?
Suspension 100%
Audit 100%
Online 95%
2023-04-16T09:28:25.105-0400 INFO piecestore uploaded {“Piece ID”: “IWO56CTG3235RA4Z4V2DVGQTICLF77ON44WCLDXPSXNKXVVK54LA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT_REPAIR”, “Size”: 181504, “Remote Address”: “5.161.50.62:41046”}
2023-04-16T09:28:25.219-0400 INFO piecestore download started {“Piece ID”: “JTOKK6FH4CBOIIGDDLGDYXEE52QPCHWS6FTWBNUMHSU7GSZPJQLQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 766976, “Size”: 2560, “Remote Address”: “184.104.224.99:12874”}
2023-04-16T09:28:25.519-0400 INFO piecestore uploaded {“Piece ID”: “DT45SCHSYXCZZ3JPQQB2JMEMNQKUTRMYJTIIZYXZSP6LAFRST4DA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Size”: 2319360, “Remote Address”: “184.104.224.98:29422”}
2023-04-16T09:28:25.543-0400 INFO piecestore downloaded {“Piece ID”: “JTOKK6FH4CBOIIGDDLGDYXEE52QPCHWS6FTWBNUMHSU7GSZPJQLQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 766976, “Size”: 2560, “Remote Address”: “184.104.224.99:12874”}
2023-04-16T09:28:25.573-0400 INFO piecedeleter delete piece sent to trash {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Piece ID”: “536ROYS253T5G5UZJDUWKLTO3M2CDSFQGMVNA6WVDPZ7B2D6DYZA”}
2023-04-16T09:28:25.952-0400 INFO piecestore upload started {“Piece ID”: “SYR5H6AYYSZ42TCYAROHFYJFVFVU6CMSIYZRI6YDJEPR2TIBFISQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 8555335953371, “Remote Address”: “5.161.149.40:14206”}
2023-04-16T09:28:26.030-0400 INFO piecestore download started {“Piece ID”: “IM6KH77V56UJABUAMBL3VBXTKADN56UABNB2NS23NB7NBQIHK7AA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 1170944, “Size”: 2560, “Remote Address”: “128.140.5.216:50658”}
2023-04-16T09:28:26.054-0400 INFO piecestore uploaded {“Piece ID”: “SYR5H6AYYSZ42TCYAROHFYJFVFVU6CMSIYZRI6YDJEPR2TIBFISQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 16384, “Remote Address”: “5.161.149.40:14206”}
2023-04-16T09:28:26.068-0400 INFO piecedeleter delete piece sent to trash {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Piece ID”: “SOTJFPV2VIY5ZAHBM7YOZPBZS5GCZIW7A2C3UGKC6XSXGZZ3A2WQ”}
2023-04-16T09:28:26.215-0400 INFO piecestore download started {“Piece ID”: “QEBMPJVHXTAAWKZFNGYPTMM3CDPNYC7BBZX7F3W5N3AX7PSRO7CA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 452608, “Size”: 2560, “Remote Address”: “188.239.191.33:60012”}
2023-04-16T09:28:26.239-0400 INFO piecestore uploaded {“Piece ID”: “7YRYSGPNDM7KAX4NEQTDXKRP5QVGTAEVIMEJNS2SU7AI4LY26ICQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Size”: 580096, “Remote Address”: “128.140.5.226:40552”}
2023-04-16T09:28:26.244-0400 INFO piecestore downloaded {“Piece ID”: “IM6KH77V56UJABUAMBL3VBXTKADN56UABNB2NS23NB7NBQIHK7AA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 1170944, “Size”: 2560, “Remote Address”: “128.140.5.216:50658”}
2023-04-16T09:28:26.610-0400 INFO piecestore download started {“Piece ID”: “K4XVJ5JY6XKU76F6YNEBUFIPZKYXIPWXPQGUR5SB7J7I26PGJDNQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 349952, “Size”: 229888, “Remote Address”: “184.104.224.99:12874”}
2023-04-16T09:28:27.009-0400 INFO piecestore download started {“Piece ID”: “ZZVUCWL5ALSVBB552ZBQKEYV4Y2APTWUSCFQO5SMMOY6XFUWQ3RA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 1070592, “Size”: 1248512, “Remote Address”: “184.104.224.98:56820”}
2023-04-16T09:28:27.244-0400 INFO piecestore download canceled {“Piece ID”: “K4XVJ5JY6XKU76F6YNEBUFIPZKYXIPWXPQGUR5SB7J7I26PGJDNQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 349952, “Size”: 163840, “Remote Address”: “184.104.224.99:12874”}
2023-04-16T09:28:27.535-0400 INFO piecestore upload started {“Piece ID”: “HJOYTZQQHWXBQKRXJSCQMYSTPHGNR44AHBHA7YQPTEGELHRRX6KQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT_REPAIR”, “Available Space”: 8555335355867, “Remote Address”: “5.161.211.30:51582”}
2023-04-16T09:28:27.655-0400 INFO piecestore uploaded {“Piece ID”: “HJOYTZQQHWXBQKRXJSCQMYSTPHGNR44AHBHA7YQPTEGELHRRX6KQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT_REPAIR”, “Size”: 2304, “Remote Address”: “5.161.211.30:51582”}
2023-04-16T09:28:27.743-0400 INFO piecestore upload started {“Piece ID”: “5YRXEJG43DO36J4LUDAAXY2HEWNMURYEILYYH3UUSSDW55V43KIQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 8555335353051, “Remote Address”: “38.88.241.42:33936”}
2023-04-16T09:28:27.931-0400 ERROR piecestore upload failed {“Piece ID”: “5YRXEJG43DO36J4LUDAAXY2HEWNMURYEILYYH3UUSSDW55V43KIQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func5:498\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:529\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 362752, “Remote Address”: “38.88.241.42:33936”}
2023-04-16T09:28:27.995-0400 INFO piecestore download canceled {“Piece ID”: “ZZVUCWL5ALSVBB552ZBQKEYV4Y2APTWUSCFQO5SMMOY6XFUWQ3RA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”, “Offset”: 1070592, “Size”: 163840, “Remote Address”: “184.104.224.98:56820”}
Looks good. Just keep the node online :+1:
