Nodes marked as Misconfigured
Hello - i have a bunch of nodes - 30+ - all “running” fine on paper (I.E logs). But all have sudden status of misconfigured.
there is no much in logs (set to error) and all nodes run fine, on different networks.
i can set the logs to info if i need to test further? I see in logs something about a corrupted directory - but again, node is fine and normal ingress. All my nodes currently have misconfigured and version 1.32.7
looks like:
The logs after a reboot:2025-08-11T13:42:13+02:00	ERROR	pieces	used-space-filewalker failed	{“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Lazy File Walker”: false, “error”: “filewalker: CreateFile P:\data\blobs\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\kc\na5jebym4euftxakxslkaylzwicr5j3gtd5iidachcqeoapjua.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “filewalker: CreateFile P:\data\blobs\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\kc\na5jebym4euftxakxslkaylzwicr5j3gtd5iidachcqeoapjua.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:78\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:129\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:83\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:783\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).add.func1:130”}2025-08-11T13:42:13+02:00	ERROR	piecestore:cache	encountered error while computing space used by satellite	{“error”: “filewalker: CreateFile P:\data\blobs\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\kc\na5jebym4euftxakxslkaylzwicr5j3gtd5iidachcqeoapjua.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “filewalker: CreateFile P:\data\blobs\v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa\kc\na5jebym4euftxakxslkaylzwicr5j3gtd5iidachcqeoapjua.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:78\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:129\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:83\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:783\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tgolang.org/x/sync/errgroup.(*Group).add.func1:130”, “SatelliteID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
It’s only “QUIC” (an optional feature) that’s misconfigured… as long as Status=Online you’re fine. You can search for other QUIC-related posts here but my impression is you can ignore it: it’s finicky enough it could be unhappy today but fine tomorrow.
Okay - thanks for this Roxor :smiley:
I would recommend to check and fix that disk.
What Alexey said, but at the very least fix that specific file/or directory, otherwise every scan it ever does will end there and bail; then rinse and repeat next time, thus getting nowhere.
2 cents,
Julio
