Nodes not grows for a long time
Not exactly - I’m observing that Used parameter +/- on the same value all this time.
And wasn’t grown to 2TB or higher.
So I’ve thought that I had mistaken in options during migration or maybe I should tune the nodes to the new setting of Storj or maybe it is because of the Russia placement.
So it’s a lot of or maybe.
Location could be part of it. Customers can choose where to geolocate their uploads, and Storj has discussed being conservative with data placement and repair settings.
But in a contradiction of this I have 2 x 3TB nodes in the different location, under the different ISP - and they’re getting normal grow.
Have you checked if your problem IP is in a sanctioned range?
I’ve made check and there is no comments in a Reason column.
