Hi trying to run multinode dashboard binary , identity generated.
multinode --config-dir /home/ubuntu/storj_dashboard/multinode --identity-dir /home/ubuntu/storj_dashboard/identity/multinode run --log.level debug
2022-02-08T13:10:01.892Z INFO Configuration loaded {"Location": "/home/ubuntu/storj_dashboard/multinode/config.yaml"}
2022-02-08T13:10:01.893Z DEBUG Anonymized tracing disabled
2022-02-08T13:10:01.931Z DEBUG db Connected to: {"db source": "file:/home/ubuntu/storj_dashboard/multinode/master.db?_journal=WAL&_busy_timeout=10000"}
2022-02-08T13:10:01.933Z INFO db Database Version {"version": 0}
2022-02-08T13:10:01.936Z DEBUG servers started {"items": ["console:endpoint"]}
Nothing is loged here.
On web browser receive “nodes web api controller: illegal base64 data at input byte 9” when trying to to add node.
/app/multinode add --node-id ************** --api-secret ************** --public-address ********** --log.stack --log.level debug
2022-02-08T14:59:16.105Z INFO Configuration loaded {"Location": "/root/.local/share/storj/multinode/config.yaml"}
2022-02-08T14:59:16.106Z DEBUG Anonymized tracing disabled
2022-02-08T14:59:16.107Z DEBUG db Connected to: {"db source": "file:/root/.local/share/storj/multinode/master.db?_journal=WAL&_busy_timeout=10000"}
2022-02-08T14:59:16.107Z DEBUG Unrecoverable error {"error": "illegal base64 data at input byte 26"}
Thanks for response.
Seems that nothing changed.
Tried to remove db and then run again. Db is created
/app# ./multinode run --log.level debug --log.stack
2022-02-09T07:52:24.577Z INFO Configuration loaded {"Location": "/root/.local/share/storj/multinode/config.yaml"}
2022-02-09T07:52:24.578Z DEBUG Anonymized tracing disabled
2022-02-09T07:52:24.595Z DEBUG db Connected to: {"db source": "file:/root/.local/share/storj/multinode/master.db?_journal=WAL&_busy_timeout=10000"}
2022-02-09T07:52:24.604Z INFO db Database Created {"version": 0}
2022-02-09T07:52:24.609Z DEBUG servers started {"items": ["console:endpoint"]}
/app/multinode add --config-dir /root/.local/share/storj/multinode --node-id=*********** --api-secret=************ --public-address=******** --log.level debug --log.stack
2022-02-09T07:57:45.053Z INFO Configuration loaded {"Location": "/root/.local/share/storj/multinode/config.yaml"}
2022-02-09T07:57:45.054Z DEBUG Anonymized tracing disabled
2022-02-09T07:57:45.057Z DEBUG db Connected to: {"db source": "file:/root/.local/share/storj/multinode/master.db?_journal=WAL&_busy_timeout=10000"}
2022-02-09T07:57:45.058Z DEBUG Unrecoverable error {"error": "illegal base64 data at input byte 4"}
# uname -a
Linux 9cfb5617274c 5.4.0-91-generic #102-Ubuntu SMP Fri Nov 5 16:31:28 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
root@9cfb5617274c:/app# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
root@9cfb5617274c:/app# /app/multinode run --log.level debug --log.stack
2022-02-09T08:34:05.058Z INFO Configuration loaded {"Location": "/root/.local/share/storj/multinode/config.yaml"}
2022-02-09T08:34:05.058Z DEBUG Anonymized tracing disabled
2022-02-09T08:34:05.059Z DEBUG db Connected to: {"db source": "file:/root/.local/share/storj/multinode/master.db?_journal=WAL&_busy_timeout=10000"}
2022-02-09T08:34:05.060Z INFO db Database Version {"version": 0}
2022-02-09T08:34:05.061Z DEBUG servers started {"items": ["console:endpoint"]}
root@9cfb5617274c:/app# /app/multinode add --config-dir /root/.local/share/storj/multinode --node-id=******** --api-secret=*********** --public-address=********* --log.level debug --log.stack
2022-02-09T08:37:38.568Z INFO Configuration loaded {"Location": "/root/.local/share/storj/multinode/config.yaml"}
2022-02-09T08:37:38.569Z DEBUG Anonymized tracing disabled
2022-02-09T08:37:38.569Z DEBUG db Connected to: {"db source": "file:/root/.local/share/storj/multinode/master.db?_journal=WAL&_busy_timeout=10000"}
2022-02-09T08:37:38.570Z DEBUG Unrecoverable error {"error": "illegal base64 data at input byte 10"}
maybe it is not platform dependent, I added 4 nodes today. Two were added successfully, two failed “Error: illegal base64 data at input byte X”, with X=20 and 30. Platform armv7. I can provide more info, but I am not sure if “secret” safe to share
Now I have created an API key with the docker exec -it storagenode /app/storagenode info command. When I try to add the API data into multinode via Powershell cli multinode add then I get this error message: Error: illegal base64 data at input byte 17. I have tried 2 times and received this error both times.
Then I created the API secret with docker exec -it storagenode /app/storagenode issue-apikey and I was able to add it to Multinode with the same previous command instantly without error message.
