Nodes with 1 audit after 1 week
I’ve opened 2 new nodes and in 1 week I didn’t receive audits. Is it normal? My dashboard status is “Online” “Ok”
Audits are very sparse early in because you’re not storing a lot of data yet. 7 days is long, but not out of the realm of possibility. If you’re online and receiving data, it’ll be fine. And don’t worry, audits become more frequent over time.
I recommend starting 1 node at a time.
Having 2 nodes behind the same ip will cause it twice as long to be fully audit.
Fully auditted server get way more data than one that is not.
different ips.
My nodes still have 0 audits :confused:
1st node have 35gb 2nd 27gb
auditScore suspensionScore onlineScore satelliteName
     1               1           1 us2.storj.io:7777
1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE
1 1 1 saltlake.tardigrade.io:7777
121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6
1 1 1 ap1.storj.io:7777
12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S
1 1 1 us1.storj.io:7777
12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
1 1 1 eu1.storj.io:7777
12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB
1 1 1 europe-north-1.tardigrade.io:7777
PS: my nodes QUIC are OK
Hi @agente
Why do you think that your nodes have 0 audits? The stats look good.
I have 0 audits.
I don’t recognise that display you’ve shown. Please run the following on the dashboard… http://localhost:14002/api/sno/satellite/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S … and post the result. It will check for US-1 stats.
You can post between three backticks to keep the data ordered:
stats
{"id":"12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S","storageDaily":[{"atRestTotal":101044616210.43765,"intervalStart":"2022-10-01T00:00:00Z"},{"atRestTotal":125714261683.72153,"intervalStart":"2022-10-02T00:00:00Z"},{"atRestTotal":146649631917.14423,"intervalStart":"2022-10-03T00:00:00Z"},{"atRestTotal":160555559937.16507,"intervalStart":"2022-10-04T00:00:00Z"}],"bandwidthDaily":[{"egress":{"repair":7680,"audit":0,"usage":467149568},"ingress":{"repair":63813632,"usage":1063123456},"delete":0,"intervalStart":"2022-10-01T00:00:00Z"},{"egress":{"repair":0,"audit":0,"usage":469183232},"ingress":{"repair":66228736,"usage":1849904896},"delete":0,"intervalStart":"2022-10-02T00:00:00Z"},{"egress":{"repair":0,"audit":0,"usage":1431473408},"ingress":{"repair":35851008,"usage":814001664},"delete":0,"intervalStart":"2022-10-03T00:00:00Z"},{"egress":{"repair":0,"audit":0,"usage":934655744},"ingress":{"repair":44774656,"usage":1482114304},"delete":0,"intervalStart":"2022-10-04T00:00:00Z"},{"egress":{"repair":0,"audit":0,"usage":484157184},"ingress":{"repair":48374272,"usage":959480320},"delete":0,"intervalStart":"2022-10-05T00:00:00Z"}],"storageSummary":515047078907.7086,"bandwidthSummary":10214293760,"egressSummary":3786626816,"ingressSummary":6427666944,"currentStorageUsed":8995987712,"audits":{"auditScore":1,"suspensionScore":1,"onlineScore":1,"satelliteName":"us1.storj.io:7777"},"auditHistory":{"score":1,"windows":[{"windowStart":"2022-10-01T00:00:00Z","totalCount":1,"onlineCount":1}]},"priceModel":{"EgressBandwidth":2000,"RepairBandwidth":1000,"AuditBandwidth":1000,"DiskSpace":150},"nodeJoinedAt":"2022-09-27T22:23:05.011567Z"}
Honestly I wouldn’t worry about it yet - with two new nodes vetting on the same IP it will be very slow for either of them to finish auditing. I would shut down one of them tbh to let one of them get audited (we are talking 5% vs 95% ingress traffic) and then spin up a new node if you like after that.
Audits do scale with how much data is stored on a node, between two of them there is most likely next to no data. Just wait a week or two more. Storj is genuinely a marathon, not a sprint
I have two separate ip (not the same subnet)
That’s okay then, just give it a week or so more and you should have an audit by then lol - as long as your scores aren’t dropping AND you’re getting ingress, everything is working normally
