Hi, I’m totally new to this.
I spun up a debian VM and mounted a NFS share from my nas to use with Storj.
Everything seems fine ish.
root@storjnode:~# docker exec -it storagenode /app/dashboard.sh
2023-12-30T22:37:52Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "operator.wallet"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "storage.allocated-bandwidth"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "operator.email"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "server.private-address"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "storage.allocated-disk-space"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "operator.wallet-features"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "healthcheck.details"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "console.address"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "server.address"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "version.server-address"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "healthcheck.enabled"}
2023-12-30T22:37:52Z INFO Invalid configuration file key {"process": "storagenode", "Key": "contact.external-address"}
2023-12-30T22:37:52Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-30T22:37:52Z INFO Identity loaded. {"process": "storagenode", "Node ID": "12D7TwwVx9fiJB8ahfq55iXP7rqzwyqPLS5g41k6npVYyzDiTbn"}
This is just stuck until I do a ctrl+c
Checking through the ip:14002 it seems kinda fine.
Although I see no progress for bandwith.
But everytime I refresh the site the used storage goes up.
The built in refresh button just get stuck at updating the site as well, not really sure what’s up with that.
Also I started with 2G of RAM. Not sure what’s necessary but I bumped it up to 6G and it’s slowly climbing upwards. Currently sitting at 4,75G used.
Again freshly created Debian VM nothing else running except for the storj docker container.
