Mhh, owner is root, so it should be correct as storJ is running on root? Anyway ran it without --user. Does not seem to matter much:
2023-12-26 00:49:24,472 INFO Set uid to user 0 succeeded
2023-12-26 00:49:24,500 INFO RPC interface 'supervisor' initialized
2023-12-26 00:49:24,500 INFO supervisord started with pid 1
2023-12-26 00:49:25,508 INFO spawned: 'processes-exit-eventlistener' with pid 53
2023-12-26 00:49:25,520 INFO spawned: 'storagenode' with pid 54
2023-12-26 00:49:25,532 INFO spawned: 'storagenode-updater' with pid 55
2023-12-26T00:49:25Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.external-address"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.operator.email"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.operator.wallet"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2023-12-26T00:49:25Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.debug-log-traffic"}
2023-12-26T00:49:25Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2023-12-26T00:49:25Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.93.2"}
2023-12-26T00:49:25Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2023-12-26T00:49:25Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:25Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:25Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:25Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "info"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "bandwidth"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "orders"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "piece_expiration"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "pieceinfo"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "piece_spaced_used"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "reputation"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "storage_usage"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "used_serial"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "satellites"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "notifications"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "heldamount"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "pricing"}
2023-12-26T00:49:25Z INFO db database does not exist {"process": "storagenode", "database": "secret"}
2023-12-26T00:49:25Z INFO server kernel support for server-side tcp fast open enabled. {"process": "storagenode"}
2023-12-26T00:49:26Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.93.2"}
2023-12-26T00:49:26Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2023-12-26T00:49:26Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.93.2"}
2023-12-26T00:49:26Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2023-12-26T00:49:26Z INFO Telemetry enabled {"process": "storagenode", "instance ID": "123jk3dKL8USr66nnRQPZp9zczABvX9as9mv5QRtxwfGZHx9VoV"}
2023-12-26T00:49:26Z INFO Event collection enabled {"process": "storagenode", "instance ID": "123jk3dKL8USr66nnRQPZp9zczABvX9as9mv5QRtxwfGZHx9VoV"}
2023-12-26 00:49:27,386 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-12-26 00:49:27,386 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-12-26 00:49:27,387 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
Error: Error creating tables for master database on storagenode: migrate: v23: database: piece_spaced_used migrate tables to database: migrate tables: unable to open database file
storj.io/storj/private/migrate.(*Migration).Run:209
storj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:370
main.cmdRun:95
main.newRunCmd.func1:32
storj.io/private/process.cleanup.func1.4:393
storj.io/private/process.cleanup.func1:411
github.com/spf13/cobra.(*Command).execute:852
github.com/spf13/cobra.(*Command).ExecuteC:960
github.com/spf13/cobra.(*Command).Execute:897
storj.io/private/process.ExecWithCustomOptions:112
main.main:30
runtime.main:267
2023-12-26 00:49:27,748 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:28,759 INFO spawned: 'storagenode' with pid 86
2023-12-26 00:49:28,762 WARN received SIGQUIT indicating exit request
2023-12-26 00:49:28,769 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2023-12-26T00:49:28Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2023-12-26 00:49:28,777 INFO stopped: storagenode-updater (exit status 0)
2023-12-26T00:49:28Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:28Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:28Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:28Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
Error: Error starting master database on storagenode: database: piece_spaced_used opening file "config/storage/piece_spaced_used.db" failed: unable to open database file: no such file or directory
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:347
storj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:324
storj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:299
storj.io/storj/storagenode/storagenodedb.OpenExisting:266
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:29,165 INFO stopped: storagenode (exit status 1)
2023-12-26 00:49:29,166 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2023-12-26 00:49:33,163 INFO Set uid to user 0 succeeded
2023-12-26 00:49:33,184 INFO RPC interface 'supervisor' initialized
2023-12-26 00:49:33,184 INFO supervisord started with pid 1
2023-12-26 00:49:34,192 INFO spawned: 'processes-exit-eventlistener' with pid 11
2023-12-26 00:49:34,204 INFO spawned: 'storagenode' with pid 12
2023-12-26 00:49:34,216 INFO spawned: 'storagenode-updater' with pid 13
2023-12-26T00:49:34Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.external-address"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.debug-log-traffic"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.operator.email"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.operator.wallet"}
2023-12-26T00:49:34Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2023-12-26T00:49:34Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2023-12-26T00:49:34Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.93.2"}
2023-12-26T00:49:34Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2023-12-26T00:49:34Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:34Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:34Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:34Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:34,548 INFO exited: storagenode (exit status 1; not expected)
2023-12-26T00:49:34Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.93.2"}
2023-12-26T00:49:34Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2023-12-26T00:49:34Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.93.2"}
2023-12-26T00:49:34Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2023-12-26 00:49:35,867 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-12-26 00:49:35,876 INFO spawned: 'storagenode' with pid 42
2023-12-26 00:49:35,878 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-12-26T00:49:36Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:36Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:36Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:36Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:36,235 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:38,247 INFO spawned: 'storagenode' with pid 51
2023-12-26T00:49:38Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:38Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:38Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:38Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:38,614 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:41,627 INFO spawned: 'storagenode' with pid 60
2023-12-26T00:49:41Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:41Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:41Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:41Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:42,013 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:43,016 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2023-12-26 00:49:44,019 WARN received SIGQUIT indicating exit request
2023-12-26 00:49:44,021 INFO waiting for processes-exit-eventlistener, storagenode-updater to die
2023-12-26T00:49:44Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2023-12-26 00:49:44,027 INFO stopped: storagenode-updater (exit status 0)
2023-12-26 00:49:45,031 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2023-12-26 00:49:46,780 INFO Set uid to user 0 succeeded
2023-12-26 00:49:46,801 INFO RPC interface 'supervisor' initialized
2023-12-26 00:49:46,802 INFO supervisord started with pid 1
2023-12-26 00:49:47,808 INFO spawned: 'processes-exit-eventlistener' with pid 11
2023-12-26 00:49:47,819 INFO spawned: 'storagenode' with pid 12
2023-12-26 00:49:47,830 INFO spawned: 'storagenode-updater' with pid 13
2023-12-26T00:49:47Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.external-address"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.operator.email"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "kademlia.operator.wallet"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.debug-log-traffic"}
2023-12-26T00:49:47Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2023-12-26T00:49:47Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2023-12-26T00:49:47Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.93.2"}
2023-12-26T00:49:47Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2023-12-26T00:49:48Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:48Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:48Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:48Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:48,192 INFO exited: storagenode (exit status 1; not expected)
2023-12-26T00:49:48Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.93.2"}
2023-12-26T00:49:48Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2023-12-26T00:49:48Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.93.2"}
2023-12-26T00:49:48Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2023-12-26 00:49:49,484 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-12-26 00:49:49,494 INFO spawned: 'storagenode' with pid 42
2023-12-26 00:49:49,497 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-12-26T00:49:49Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:49Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:49Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:49Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:49,855 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:51,866 INFO spawned: 'storagenode' with pid 51
2023-12-26T00:49:52Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:52Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:52Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:52Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:52,249 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:55,263 INFO spawned: 'storagenode' with pid 60
2023-12-26T00:49:55Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-12-26T00:49:55Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-12-26T00:49:55Z INFO Operator email {"process": "storagenode", "Address": "weddingCrasher@yandex.com"}
2023-12-26T00:49:55Z INFO Operator wallet {"process": "storagenode", "Address": "0xB915d96D7a36559645b30c19ceFFD97A260eE734"}
main.cmdRun:62
main.main:30
runtime.main:267
2023-12-26 00:49:55,660 INFO exited: storagenode (exit status 1; not expected)
2023-12-26 00:49:56,662 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2023-12-26 00:49:57,665 WARN received SIGQUIT indicating exit request
2023-12-26 00:49:57,666 INFO waiting for processes-exit-eventlistener, storagenode-updater to die
2023-12-26T00:49:57Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
and
root@raspberrypi4:/mnt/Elements# ls -l /mnt/Elements12TB/storJ/storage
insgesamt 197777
-rwxrwxrwx 1 root root 24576 Dez 26 01:49 bandwidth.db
drwxrwxrwx 1 root root 0 Jul 16 2019 blob
drwxrwxrwx 1 root root 4096 Jan 7 2021 blobs
drwxrwxrwx 1 root root 4096 Dez 18 23:15 DB_Backups
drwxrwxrwx 1 root root 24576 Dez 17 12:32 garbage
-rwxrwxrwx 1 root root 135168 Dez 26 01:49 info.db
-rwxrwxrwx 1 root root 16384 Dez 26 01:49 orders.db
-rwxrwxrwx 1 root root 20480 Dez 26 01:49 piece_expiration.db
-rwxrwxrwx 1 root root 16384 Dez 26 01:49 pieceinfo.db
-rwxrwxrwx 1 root root 4096 Dez 26 01:49 piece_spaced_used.db
-rwxrwxrwx 1 root root 0 Dez 26 01:49 piece_spaced_used.db-wal
-rwxrwxrwx 1 root root 4096 Dez 26 01:49 reputation.db
-rwxrwxrwx 1 root root 4096 Dez 26 01:49 satellites.db
-rwxrwxrwx 1 root root 32 Dez 18 18:10 storage-dir-verification
-rwxrwxrwx 1 root root 4096 Dez 26 01:49 storage_usage.db
drwxrwxrwx 1 root root 202252288 Dez 17 12:33 temp
drwxrwxrwx 1 root root 4096 Jan 12 2021 trash
-rwxrwxrwx 1 root root 4096 Dez 26 01:49 used_serial.db
-rwxrwxrwx 1 root root 0 Sep 22 2022 write-test1265540363
-rwxrwxrwx 1 root root 0 Mär 7 2023 write-test1324701481
-rwxrwxrwx 1 root root 0 Mär 17 2023 write-test1477702234
-rwxrwxrwx 1 root root 0 Sep 22 2022 write-test1839237374
-rwxrwxrwx 1 root root 0 Sep 21 2022 write-test1867707981
-rwxrwxrwx 1 root root 0 Mär 18 2023 write-test1913174638
-rwxrwxrwx 1 root root 0 Mär 18 2023 write-test192220591
-rwxrwxrwx 1 root root 0 Mär 16 2023 write-test2284224945
-rwxrwxrwx 1 root root 0 Mär 9 2023 write-test233384524
-rwxrwxrwx 1 root root 0 Sep 19 2022 write-test2354714472
-rwxrwxrwx 1 root root 0 Sep 16 2022 write-test243715213
-rwxrwxrwx 1 root root 0 Mär 18 2023 write-test2457967941
-rwxrwxrwx 1 root root 0 Sep 24 2022 write-test2729741602
-rwxrwxrwx 1 root root 0 Sep 15 2022 write-test2804473926
-rwxrwxrwx 1 root root 0 Sep 19 2022 write-test3087336888
-rwxrwxrwx 1 root root 0 Mär 17 2023 write-test3267077572
-rwxrwxrwx 1 root root 0 Sep 22 2022 write-test3297119974
-rwxrwxrwx 1 root root 0 Mär 8 2023 write-test3598281214
-rwxrwxrwx 1 root root 0 Mär 8 2023 write-test3847121906
-rwxrwxrwx 1 root root 0 Mär 18 2023 write-test4026102791
-rwxrwxrwx 1 root root 0 Mär 9 2023 write-test4146183310
-rwxrwxrwx 1 root root 0 Sep 19 2022 write-test423293173
-rwxrwxrwx 1 root root 0 Sep 21 2022 write-test471064762
-rwxrwxrwx 1 root root 0 Sep 14 2022 write-test530076394
-rwxrwxrwx 1 root root 0 Mär 9 2023 write-test543405008
-rwxrwxrwx 1 root root 0 Sep 19 2022 write-test594408963
-rwxrwxrwx 1 root root 0 Mär 17 2023 write-test669119877
-rwxrwxrwx 1 root root 0 Mär 18 2023 write-test786796008
-rwxrwxrwx 1 root root 0 Sep 19 2022 write-test872397235
-rwxrwxrwx 1 root root 0 Sep 21 2022 write-test91682543
-rwxrwxrwx 1 root root 0 Sep 24 2022 write-test917766394
