Hi! My node has been working for 4 month without problem but today I have had to reboot it and it stay offline. I have checked every thing I think is important. Conection is ok, DUC client is ok. Router ports are ok and firewall of windows 10 seems is ok with the exception for 28967 port.
Can I have any suggestion, please. I have been several hours reading in the forum and I have followed every tip that I have seen… but It doesn’t work.
Thanks!
Are you sure you are offline? SNO board is broken with latest update. Check your logs and see if you are getting pieces
I’m not sure. Storagenode.log seems like this:
2020-09-16T23:09:37.944+0100 | INFO | piecestore | download started | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:09:41.110+0100 | INFO | piecestore | downloaded | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:09:50.138+0100 | INFO | piecestore | download started | {“Piece ID”: “SK2VC3HP47UAKHLN4FXUIARDMK2TPL7VC7JDEIDZ4U5FIBRLCGKQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:09:54.953+0100 | INFO | piecestore | downloaded | {“Piece ID”: “SK2VC3HP47UAKHLN4FXUIARDMK2TPL7VC7JDEIDZ4U5FIBRLCGKQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:09:55.631+0100 | INFO | piecestore | download started | {“Piece ID”: “SK2VC3HP47UAKHLN4FXUIARDMK2TPL7VC7JDEIDZ4U5FIBRLCGKQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:09:59.681+0100 | INFO | piecestore | downloaded | {“Piece ID”: “SK2VC3HP47UAKHLN4FXUIARDMK2TPL7VC7JDEIDZ4U5FIBRLCGKQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:10:15.551+0100 | INFO | piecedeleter | deleted | {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Piece ID”: “JPNH2DT2454RHPY654STQLWAJTHHBDFX3UXCYLAQUQIUWESUQL3A”} |
2020-09-16T23:10:26.424+0100 | INFO | piecestore | download started | {“Piece ID”: “ZSQ2AMTAYKXM2GJU7YHQAHXOUIIOP75BFIJRX7QOAZQNUYXNIHYA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
2020-09-16T23:10:26.683+0100 | INFO | piecestore | downloaded | {“Piece ID”: “ZSQ2AMTAYKXM2GJU7YHQAHXOUIIOP75BFIJRX7QOAZQNUYXNIHYA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
2020-09-16T23:10:44.326+0100 | INFO | piecestore | download started | {“Piece ID”: “FCKBJWRSKEL5LNAKIGW6TEYRJYWBWNF76D6TVTQB3EVWB4FDCA6A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET”} |
2020-09-16T23:10:47.352+0100 | INFO | piecestore | download started | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:10:48.571+0100 | INFO | piecestore | downloaded | {“Piece ID”: “FCKBJWRSKEL5LNAKIGW6TEYRJYWBWNF76D6TVTQB3EVWB4FDCA6A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET”} |
2020-09-16T23:10:51.036+0100 | INFO | piecestore | downloaded | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:10:55.503+0100 | INFO | piecestore | download started | {“Piece ID”: “GXRIFMY6IC7JP2E2NMDP3P4EWEVLELXXHQBYQYIKKTCOJJMAUCMQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_REPAIR”} |
2020-09-16T23:10:56.614+0100 | INFO | piecestore | downloaded | {“Piece ID”: “GXRIFMY6IC7JP2E2NMDP3P4EWEVLELXXHQBYQYIKKTCOJJMAUCMQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_REPAIR”} |
2020-09-16T23:11:09.824+0100 | INFO | piecestore | download started | {“Piece ID”: “LXYMA6WN5V6N6BVLPXI3DPOQZWFUKDPKEGEAQ2JYZEFWO2SULIEA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_REPAIR”} |
2020-09-16T23:11:10.604+0100 | INFO | piecestore | downloaded | {“Piece ID”: “LXYMA6WN5V6N6BVLPXI3DPOQZWFUKDPKEGEAQ2JYZEFWO2SULIEA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_REPAIR”} |
2020-09-16T23:11:36.477+0100 | INFO | piecedeleter | deleted | {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Piece ID”: “MWJVVCW7I3CN7ZFFWEESPMOX5AR4LJ7OUZAL2KESIM23PI2ZEE4A”} |
2020-09-16T23:11:37.718+0100 | INFO | piecestore | download started | {“Piece ID”: “6OXJ6NMECKR5OASWRQPYTHJ4MK34KD5GCVD3NJXK6OQMAGTBCY7Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET”} |
2020-09-16T23:11:41.059+0100 | INFO | piecestore | downloaded | {“Piece ID”: “6OXJ6NMECKR5OASWRQPYTHJ4MK34KD5GCVD3NJXK6OQMAGTBCY7Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET”} |
2020-09-16T23:12:02.970+0100 | INFO | piecestore | download started | {“Piece ID”: “SYJZC3TKD6DU6S3DH43H5O7OPJFNARQGYFU64DZTKKVVOOFFKNIQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_REPAIR”} |
2020-09-16T23:12:04.584+0100 | INFO | piecestore | downloaded | {“Piece ID”: “SYJZC3TKD6DU6S3DH43H5O7OPJFNARQGYFU64DZTKKVVOOFFKNIQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_REPAIR”} |
2020-09-16T23:12:10.646+0100 | INFO | piecestore | download started | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:12:11.648+0100 | INFO | piecestore | download started | {“Piece ID”: “E7H4H6EMH3XHDENMHC3ESYL4LB5LPD2XTACARMV34AT4SEH5JEVA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”} |
2020-09-16T23:12:12.335+0100 | INFO | piecestore | downloaded | {“Piece ID”: “E7H4H6EMH3XHDENMHC3ESYL4LB5LPD2XTACARMV34AT4SEH5JEVA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”} |
2020-09-16T23:12:13.960+0100 | INFO | piecestore | download started | {“Piece ID”: “6OXJ6NMECKR5OASWRQPYTHJ4MK34KD5GCVD3NJXK6OQMAGTBCY7Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET”} |
2020-09-16T23:12:14.543+0100 | INFO | piecestore | downloaded | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:12:18.222+0100 | INFO | piecestore | downloaded | {“Piece ID”: “6OXJ6NMECKR5OASWRQPYTHJ4MK34KD5GCVD3NJXK6OQMAGTBCY7Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET”} |
2020-09-16T23:12:58.580+0100 | INFO | piecestore | download started | {“Piece ID”: “OCBMDABUYGQL2UYKOAD6W3NLCTISJYJPEWYMA7BUKQ2IKFQHYLNA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”} |
2020-09-16T23:13:00.407+0100 | INFO | piecestore | downloaded | {“Piece ID”: “OCBMDABUYGQL2UYKOAD6W3NLCTISJYJPEWYMA7BUKQ2IKFQHYLNA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”} |
2020-09-16T23:13:10.557+0100 | INFO | piecestore | download started | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:14.901+0100 | INFO | piecestore | downloaded | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:16.994+0100 | INFO | piecestore | download started | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:18.546+0100 | INFO | piecestore | download started | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:21.687+0100 | INFO | piecestore | downloaded | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:21.817+0100 | INFO | piecestore | download started | {“Piece ID”: “D4JW6SHSGULZK64XNVDLKWSG3E7WTWXEPHV5XKTB7KEDODM6TSQQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
2020-09-16T23:13:22.310+0100 | INFO | piecestore | downloaded | {“Piece ID”: “D4JW6SHSGULZK64XNVDLKWSG3E7WTWXEPHV5XKTB7KEDODM6TSQQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”} |
2020-09-16T23:13:22.329+0100 | INFO | piecestore | downloaded | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:25.618+0100 | INFO | piecestore | download started | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:29.737+0100 | INFO | piecestore | downloaded | {“Piece ID”: “APIXKO27IHSNPWNJ34WA2LWTJV4QLDA5AOYCX3OS5BL2UAXFSR2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:30.441+0100 | INFO | piecestore | download started | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
2020-09-16T23:13:34.645+0100 | INFO | piecestore | downloaded | {“Piece ID”: “DVIS3R5FTOASEV3CCX45RQTMMMVZZKILTYCDNI3MIVIK4KSDEOTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”} |
It has a good look, isn’t it??
Got the same, so i expect that this is a common problem
You can use the CLI dashboard to check, that one still works correctly.
I think it’s fine. I had read about offline but not the new post about that. I have seen my node output is growing up but slowly. thank you so much.
