Hello,
my Node reports to be offline after the setup.
The port is open and reachable.
Log:
log”:“2019-11-25T19:07:09.593Z\u0009\u001b[34mINFO\u001b[0m\u0009Configuration loaded from: /app/config/config.yaml\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:09.593796833Z”}
{“log”:“2019-11-25T19:07:09.602Z\u0009\u001b[34mINFO\u001b[0m\u0009Operator email: XXXXXXXXXXXXXXX\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:09.602823719Z”}
{“log”:“2019-11-25T19:07:09.602Z\u0009\u001b[34mINFO\u001b[0m\u0009operator wallet: 0x47ecF400b027c5afDB5B597c19D82803bF448786\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:09.60285295Z”}
{“log”:“2019-11-25T19:07:13.069Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:13.070141085Z”}
{“log”:“2019-11-25T19:07:15.050Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.0\u0009Initial setup\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.05088948Z”}
{“log”:“2019-11-25T19:07:15.052Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.1\u0009Network Wipe #2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.053023848Z”}
{“log”:“2019-11-25T19:07:15.053Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.2\u0009Add tracking of deletion failures.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398486296Z”}
{“log”:“2019-11-25T19:07:15.053Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.3\u0009Add vouchersDB for storing and retrieving vouchers.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398513902Z”}
{“log”:“2019-11-25T19:07:15.054Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.4\u0009Add index on pieceinfo expireation\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398520382Z”}
{“log”:“2019-11-25T19:07:15.055Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.5\u0009Partial Network Wipe - Tardigrade Satellites\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398526036Z”}
{“log”:“2019-11-25T19:07:15.055Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.6\u0009Add creation date.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398531494Z”}
{“log”:“2019-11-25T19:07:15.056Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.7\u0009Drop certificate table.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.39853678Z”}
{“log”:“2019-11-25T19:07:15.056Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.8\u0009Drop old used serials and remove pieceinfo_deletion_failed index.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398542922Z”}
{“log”:“2019-11-25T19:07:15.057Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.9\u0009Add order limit table.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398552704Z”}
{“log”:“2019-11-25T19:07:15.058Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.10\u0009Optimize index usage.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398560872Z”}
{“log”:“2019-11-25T19:07:15.058Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.11\u0009Create bandwidth_usage_rollup table.\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398566752Z”}
{“log”:“2019-11-25T19:07:15.059Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.12\u0009Clear Tables from Alpha data\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398572472Z”}
{“log”:“2019-11-25T19:07:15.060Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.13\u0009Free Storagenodes from trash data\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398577901Z”}
{“log”:“2019-11-25T19:07:15.060Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.14\u0009Free Storagenodes from orphaned tmp data\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398583331Z”}
{“log”:“2019-11-25T19:07:15.060Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.15\u0009Start piece_expirations table, deprecate pieceinfo table\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398588694Z”}
{“log”:“2019-11-25T19:07:15.061Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.16\u0009Add reputation and storage usage cache tables\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398594092Z”}
{“log”:“2019-11-25T19:07:15.062Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.17\u0009Create piece_space_used table\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398599575Z”}
{“log”:“2019-11-25T19:07:15.062Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.18\u0009Drop vouchers table\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398604919Z”}
{“log”:“2019-11-25T19:07:15.063Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.19\u0009Add disqualified field to reputation\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.39862594Z”}
{“log”:“2019-11-25T19:07:15.064Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.20\u0009Empty storage_usage table, rename storage_usage.timestamp to interval_start\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.3986358Z”}
{“log”:“2019-11-25T19:07:15.064Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.21\u0009Create satellites table and satellites_exit_progress table\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398641772Z”}
{“log”:“2019-11-25T19:07:15.065Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.22\u0009Vacuum info db\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398646752Z”}
{“log”:“2019-11-25T19:07:15.068Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.23\u0009Split into multiple sqlite databases\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:15.398651608Z”}
{“log”:“2019-11-25T19:07:36.924Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.24\u0009Drop unneeded tables in deprecatedInfoDB\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:36.92505339Z”}
{“log”:“2019-11-25T19:07:38.662Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration.25\u0009Remove address from satellites table\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.66291386Z”}
{“log”:“2019-11-25T19:07:38.663Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration\u0009Database Version\u0009{“version”: 25}\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.663710522Z”}
{“log”:“2019-11-25T19:07:38.664Z\u0009\u001b[34mINFO\u001b[0m\u0009contact:chore\u0009Storagenode contact chore starting up\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.664416915Z”}
{“log”:“2019-11-25T19:07:38.664Z\u0009\u001b[34mINFO\u001b[0m\u0009bandwidth\u0009Performing bandwidth usage rollups\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.664442027Z”}
{“log”:“2019-11-25T19:07:38.664Z\u0009\u001b[34mINFO\u001b[0m\u0009Node 1e7SPKFRANfkMB7PHQUbsXLTmNZcvkww9UKExyjHz9V4KCjJsF started\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.66488801Z”}
{“log”:“2019-11-25T19:07:38.664Z\u0009\u001b[34mINFO\u001b[0m\u0009Public server started on [::]:28967\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.664902932Z”}
{“log”:“2019-11-25T19:07:38.664Z\u0009\u001b[34mINFO\u001b[0m\u0009Private server started on 127.0.0.1:7778\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.664909801Z”}
{“log”:“2019-11-25T19:07:38.665Z\u0009\u001b[34mINFO\u001b[0m\u0009piecestore:monitor\u0009Remaining Bandwidth\u0009{“bytes”: 10000000000000000}\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.665661086Z”}
{“log”:“2019-11-25T19:07:38.779Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:07:38.779648011Z”}
{“log”:“2019-11-25T19:22:39.124Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:22:39.125104917Z”}
{“log”:“2019-11-25T19:37:39.109Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:37:39.109247032Z”}
{“log”:“2019-11-25T19:52:39.112Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:52:39.112435294Z”}
{“log”:“2019-11-25T19:55:01.947Z\u0009\u001b[34mINFO\u001b[0m\u0009Got a signal from the OS: “terminated”\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:01.947694693Z”}
{“log”:“2019-11-25T19:55:33.769Z\u0009\u001b[34mINFO\u001b[0m\u0009Configuration loaded from: /app/config/config.yaml\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:33.76968786Z”}
{“log”:“2019-11-25T19:55:33.780Z\u0009\u001b[34mINFO\u001b[0m\u0009Operator email: xxxxxxxxxxx\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:33.780625447Z”}
{“log”:“2019-11-25T19:55:33.780Z\u0009\u001b[34mINFO\u001b[0m\u0009operator wallet:xxxxxxxxxxx\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:33.780643025Z”}
{“log”:“2019-11-25T19:55:34.912Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.912642426Z”}
{“log”:“2019-11-25T19:55:34.919Z\u0009\u001b[34mINFO\u001b[0m\u0009db.migration\u0009Database Version\u0009{“version”: 25}\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.919220175Z”}
{“log”:“2019-11-25T19:55:34.920Z\u0009\u001b[34mINFO\u001b[0m\u0009bandwidth\u0009Performing bandwidth usage rollups\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.9203019Z”}
{“log”:“2019-11-25T19:55:34.920Z\u0009\u001b[34mINFO\u001b[0m\u0009contact:chore\u0009Storagenode contact chore starting up\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.92033377Z”}
{“log”:“2019-11-25T19:55:34.920Z\u0009\u001b[34mINFO\u001b[0m\u0009Node 1e7SPKFRANfkMB7PHQUbsXLTmNZcvkww9UKExyjHz9V4KCjJsF started\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.920349438Z”}
{“log”:“2019-11-25T19:55:34.920Z\u0009\u001b[34mINFO\u001b[0m\u0009Public server started on [::]:28967\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.920366315Z”}
{“log”:“2019-11-25T19:55:34.920Z\u0009\u001b[34mINFO\u001b[0m\u0009Private server started on 127.0.0.1:7778\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.920380798Z”}
{“log”:“2019-11-25T19:55:34.922Z\u0009\u001b[34mINFO\u001b[0m\u0009piecestore:monitor\u0009Remaining Bandwidth\u0009{“bytes”: 10000000000000000}\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:34.922797851Z”}
{“log”:“2019-11-25T19:55:35.034Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T19:55:35.03459504Z”}
{“log”:“2019-11-25T20:10:35.378Z\u0009\u001b[34mINFO\u001b[0m\u0009version\u0009running on version v0.26.2\n”,“stream”:“stderr”,“time”:“2019-11-25T20:10:35.378491498Z”}
What can I do?
Thanks!
