Hi. I’ve spent half a day trying to get my new node online. Although I spend many years with GPU mining, Storj requires a good chunk of networking knowledge. Hope you all could help me on this rather basic question.
I use x to indicate numbers
My set up is simple: Router > unmanaged switch > Win10
The setting for each step is
1. Router 1.1 Port Forwarding
Local ip: 192.168.1.x
Local port: 28967
Protocol: TCP+UDP
Remote ip address: 100.x.x.x ( ip address given when I registered for DDNS at noip.com)
Remote Port range: 28967
1.2 DDNS
I also set up the noip within my router. The router indicates that it’s synconized.
2. Unmanaged switch
I don’t think there is anything to do with this part
3. Win10
I follow all the main guide. identity set up and verified.
Put the firewall exception rule for inbound. TCP@28967
Get to the dashboard but it’s shown as offline. Also try to change the inbound rule to allow all port all protocol but still the same
No IP DUC program for Win10 is installed. It runs normally.
Put in 100.x.x.x ( ip address given when I registered for DDNS at noip.com)
Put port 28967
My questions are
Are there anything wrong with these inputs and set up. Any advice on fixing this port forwarding issue
After my change in setting, how do I apply setting to the node. Will the node pick up the communication after the port forwarding set up by itself, or do I need to restart PC/ type command line
what is a difference between IP given by noIP and my public IP address.
The idea is: The local ip updater detects any ip change and informs the DDNS service about your actual ip. Anyone calling your DDNS hostname will then receive your actual ip from them and can connect to you.
You should always test everything with your public ip before moving forward with a ddns service to make sure nothing is affecting the outcome. Also You need to make sure to forward the port to the correct computer ive seen many times of not forwarding the port to the correct pc.
It’s resolved for port forwarding. My provider has their own DDNS service provided for user for free.
After I use that instead of noIP, it works and online now.
I feel a very great vibe in this community. Thank you for your quick and enthusiastic support
