Hi,
i have running 3 Nodes. But 2 of them are offline since a couple of days. All running at the same PC with Windows 10.
I have nothing changed on the system.
It looks like this:
Try these steps
The ports where open…but the system cannot start the nodes.
check logs there shold be some errors if nodes ho offline.
2020-08-30T11:34:29.123+0200 FATAL Unrecoverable error {“error”: “Error starting master database on storagenode: storage node database error: file is not a database\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:363\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:349\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:313\n\tstorj.io/storj/storagenode/storagenodedb.Open:245\n\tmain.cmdRun:151\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”, “errorVerbose”: “Error starting master database on storagenode: storage node database error: file is not a database\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:363\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:349\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:313\n\tstorj.io/storj/storagenode/storagenodedb.Open:245\n\tmain.cmdRun:151\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n\tmain.cmdRun:153\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Its the only error in the log…
database is currapted fro some reason, Power cutoff?
@Alexey usualy know how to fix them.
It is posible, there is some information in knolagebase.
I don´t know…the PC is running as well…no power cutoff.
OK i will check the base
Please, figure out which one is corrupted:
It will not help to fix the “file is not database” error, but can help find out which one unrecoverable corrupted.
Post a check result here.
