Please, show the last 20 lines from your logs: https://documentation.storj.io/resources/faq/check-logs
PS C:\Users\Bob> Get-Content “$env:ProgramFiles/Storj/Storage Node/storagenode.log” -Tail 20 -Wait
2020-10-01T21:12:46.264-0400 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-10-01T21:13:06.267-0400 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “error”: “rpc: context deadline exceeded”, “errorVerbose”: “rpc: context deadline exceeded\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.267-0400 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-10-01T21:13:06.267-0400 INFO Node 1wLVsXkBgctVLRk4Pq3hPYMmBcPou8mmZ1sX4nqH6yyuZg2pJ5 started
2020-10-01T21:13:06.267-0400 INFO Public server started on [::]:28967
2020-10-01T21:13:06.267-0400 INFO Private server started on 127.0.0.1:7778
2020-10-01T21:13:06.267-0400 INFO trust Scheduling next refresh {“after”: “4h0m4.114018571s”}
2020-10-01T21:13:06.267-0400 INFO bandwidth Performing bandwidth usage rollups
2020-10-01T21:13:06.272-0400 WARN piecestore:monitor Disk space is less than requested. Allocated space is {“bytes”: 99766604672}
2020-10-01T21:13:06.272-0400 ERROR piecestore:monitor Total disk space is less than required minimum {“bytes”: 500000000000}
2020-10-01T21:13:06.272-0400 ERROR services unexpected shutdown of a runner {“name”: “piecestore:monitor”, “error”: “piecestore monitor: disk space requirement not met”, “errorVerbose”: “piecestore monitor: disk space requirement not met\n\tstorj.io/storj/storagenode/monitor.(*Service).Run:113\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:57\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.273-0400 ERROR nodestats:cache Get pricing-model/join date failed
{“error”: “context canceled”}
2020-10-01T21:13:06.336-0400 ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:150\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:359\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.371-0400 ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:150\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:359\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.396-0400 ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:150\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:359\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.428-0400 ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:150\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:359\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.462-0400 ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storage/filestore.(*blobStore).EmptyTrash:150\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:310\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:359\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1:51\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.465-0400 ERROR piecestore:cache error getting current space used calculation: {“error”: “context canceled; context canceled; context canceled; context canceled; context canceled”, “errorVerbose”: “group:\n— context canceled\n— context canceled\n— context canceled\n— context canceled\n— context canceled”}
2020-10-01T21:13:06.779-0400 ERROR servers unexpected shutdown of a runner {“name”: “debug”, “error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-10-01T21:13:06.966-0400 FATAL Unrecoverable error {“error”: “piecestore monitor: disk space requirement not met”, “errorVerbose”: “piecestore monitor: disk space requirement not met\n\tstorj.io/storj/storagenode/monitor.(*Service).Run:113\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:57\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Your drive for data have only 99GB of free space.
Make sure that you specified the right folder with existing data when reinstalled the storagenode. It’s a storage.path parameter in the "C:\Program Files\Storj\Storage Node\config.yaml" configuration.
These are the screen shots of the space available and the path from the .yaml file. Not sure where you saw the 99GB of free space
Ran install again, back on line.
como hiciste para resolverlo? tengo el mismo problema
