Once again Storj has left the building. Have checked all that I am able to check but I’m sure that there’s something else. Has been running fine until now.
Please, show 20 last lines from your logs: https://documentation.storj.io/resources/faq/check-logs
2020-09-26T12:59:17.573-0400 INFO piecestore upload started {“Piece ID”: “DLLGAAIKEGMWN2DWBRAOT2UOCD4T7MI2J37V6GFPYGNWKKGGBRQA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT_REPAIR”, “Available Space”: 4931935862528}
2020-09-26T12:59:18.414-0400 INFO piecestore upload started {“Piece ID”: “KMDCPCOMOX5GCMPJ3KXLE5FWRJQRXLS744HN2PHSTGZOF46ECBJQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”, “Available Space”: 4931935862528}
2020-09-26T12:59:20.678-0400 INFO piecestore uploaded {“Piece ID”: “DLLGAAIKEGMWN2DWBRAOT2UOCD4T7MI2J37V6GFPYGNWKKGGBRQA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT_REPAIR”}
2020-09-26T12:59:32.333-0400 INFO piecestore upload started {“Piece ID”: “6E4RETLXU2LHIXRTEY5GMRPTNZYFRQIZK3PFPOGUAS6IJFWJY2SA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT_REPAIR”, “Available Space”: 4931934834432}
2020-09-26T12:59:32.926-0400 INFO piecestore uploaded {“Piece ID”: “6E4RETLXU2LHIXRTEY5GMRPTNZYFRQIZK3PFPOGUAS6IJFWJY2SA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT_REPAIR”}
2020-09-26T12:59:36.609-0400 INFO piecestore uploaded {“Piece ID”: “KMDCPCOMOX5GCMPJ3KXLE5FWRJQRXLS744HN2PHSTGZOF46ECBJQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”}
2020-09-26T12:59:39.898-0400 INFO piecestore upload started {“Piece ID”: “3HNTQQ7TEBNJN42JGYE4Q3RYMW67AMAQB2GUP3J4HXYFHG3OXPZQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT”, “Available Space”: 4931932326656}
2020-09-26T12:59:40.042-0400 INFO piecestore uploaded {“Piece ID”: “3HNTQQ7TEBNJN42JGYE4Q3RYMW67AMAQB2GUP3J4HXYFHG3OXPZQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT”}
2020-09-26T12:59:40.292-0400 INFO piecestore upload started {“Piece ID”: “BC73YOFZQ35F52XD3IL6AEIGBNUPW36Z4HEB7SQ53EKOU44NPR6A”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”, “Available Space”: 4931932320000}
2020-09-26T12:59:47.681-0400 INFO Got a signal from the OS: “terminated”
2020-09-26T12:59:47.770-0400 INFO contact:service context cancelled {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”}
2020-09-26T12:59:47.785-0400 INFO piecestore upload canceled {“Piece ID”: “BC73YOFZQ35F52XD3IL6AEIGBNUPW36Z4HEB7SQ53EKOU44NPR6A”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”}
2020-09-26T12:59:47.796-0400 INFO piecestore upload canceled {“Piece ID”: “K2GHNABN6IDIKHAA54MXJVTY2GZAB3T2LOQSAEZ4TIZE6HRKBTTQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT_REPAIR”}
2020-09-26T12:59:48.297-0400 ERROR servers unexpected shutdown of a runner {“name”: “debug”, “error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-26T12:59:48.456-0400 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-26T13:22:39.017-0400 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-09-26T13:22:39.066-0400 INFO Operator email {“Address”: “brl1953@zoominternet.net”}
2020-09-26T13:22:39.066-0400 INFO Operator wallet {“Address”: “0x4921452244367c3ED9addEBE989A2ccd7a18Ec34”}
2020-09-26T13:22:39.073-0400 ERROR Invalid configuration. {“error”: “invalid contact.external-address: lookup “musicman9566.ddns.net” failed: lookup musicman9566.ddns.net: no such host”, “errorVerbose”: “invalid contact.external-address: lookup “musicman9566.ddns.net” failed: lookup musicman9566.ddns.net: no such host\n\tstorj.io/storj/storagenode.(*Config).Verify:150\n\tmain.cmdRun:146\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-26T13:22:39.073-0400 FATAL Unrecoverable error {“error”: “invalid contact.external-address: lookup “musicman9566.ddns.net” failed: lookup musicman9566.ddns.net: no such host”, “errorVerbose”: “invalid contact.external-address: lookup “musicman9566.ddns.net” failed: lookup musicman9566.ddns.net: no such host\n\tstorj.io/storj/storagenode.(*Config).Verify:150\n\tmain.cmdRun:146\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Please, check your DDNS updater.
I would like to recommend to use a DDNS updater on your router and uninstall a software updater.
Also, try to use a 8.8.8.8 as your default DNS server instead of current one.
I can not get access to my router through a browser, I have to contact the ISP each time I have an issue. Is this something that I can do from my computer?
Yes, then install the DUC and login to your DDNS account in it to update your DDNS hostname.
You can change a default DNS on your PC:
I have changed the DNS to 8.8.8.8 but I have forgotten how or where about the DUC.
If you setup the DDNS hostname on no-ip.com, you should download and install their program DUC to updates your DDNS hostname automatically when your public IP has changed.
I have it running, is this something that I should continue to run in the background all the time? I just started it , where do I update my DDNS hostname?
It should be running every time. Also, please, check is your subscription confirmed? (you should confirm it every month by click on the link in the email, when it’s arrive)
You can forcedly update your DDNS by button “Update now”.
Please, compare the IP in the DUC with IP on https://www.yougetsignal.com/tools/open-ports/
Since you do not have an access to your router I can only hope that it has the same WAN IP.
I did the refresh but I didn’t think it would show the open port unless the node was at least running. The IP’s do match
Yes, of course. Try to start the storagenode, then check your logs for fatal errors.
I attempted a start but got the same as above. “The site can’t be reached” Would I have to reboot?
Let me check the log.
More like reboot of your router then Windows, if doesn’t help
Please, open a cmd.exe as Administrator
sc.exe config storagenode depend= dnscache start= delayed-auto
Then restart the storagenode service.
Did a re-install - working now
But you have tried as a casual user.
I’m sorry to say the operation of Storj on my computer is becoming ridiculous to keep running. One more time it has stopped running and restart is unsuccessful. I ran the above cmd line in what I thought was Admin. mode as indicated by the C:\WINDOWS\system32\com.exe. If there is another, I’m unaware of it and also unaware of how to access it.
Anyway I can no longer get it to start. I even re-installed…any help would be great.
