One node crashing on startup with " a bytes-like object is required, not 'str'"
I have a docker compose stack with like 5 different nodes. this morning I was greeted with ONE node which was failed. when I try to start the stack I get this error and the whole stack fails.
xxx@sdocker:~$ sudo docker-compose up
storj14004 is up-to-date
storj14003 is up-to-date
Starting storj14007 ...
storj14002 is up-to-date
storj14005 is up-to-date
ERROR: for storj14007  a bytes-like object is required, not 'str'
  File "/usr/lib/python3/dist-packages/docker/api/client.py", line 261, in _raise_for_status
    response.raise_for_status()
  File "/usr/lib/python3/dist-packages/requests/models.py", line 943, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http+docker://localhost/v1.22/containers/2c843c59a2d942606a9fe76ad5c9960f193333fce71c469b42035d05d16245df/start
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/compose/service.py", line 625, in start_container
    container.start()
  File "/usr/lib/python3/dist-packages/compose/container.py", line 241, in start
    return self.client.start(self.id, **options)
  File "/usr/lib/python3/dist-packages/docker/utils/decorators.py", line 19, in wrapped
    return f(self, resource_id, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/docker/api/container.py", line 1095, in start
    self._raise_for_status(res)
  File "/usr/lib/python3/dist-packages/docker/api/client.py", line 263, in _raise_for_status
    raise create_api_error_from_http_exception(e)
  File "/usr/lib/python3/dist-packages/docker/errors.py", line 31, in create_api_error_from_http_exception
    raise cls(e, response=response, explanation=explanation)
docker.errors.APIError: 500 Server Error: Internal Server Error ("b"error while creating mount source path '/srv/storj4': mkdir /srv/storj4: file exists"")
  File "/usr/bin/docker-compose", line 11, in <module>
    load_entry_point('docker-compose==1.25.0', 'console_scripts', 'docker-compose')()
  File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 72, in main
    command()
  File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 128, in perform_command
    handler(command, command_options)
  File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1107, in up
    to_attach = up(False)
  File "/usr/lib/python3/dist-packages/compose/cli/main.py", line 1088, in up
    return self.project.up(
  File "/usr/lib/python3/dist-packages/compose/project.py", line 565, in up
    results, errors = parallel.parallel_execute(
  File "/usr/lib/python3/dist-packages/compose/parallel.py", line 112, in parallel_execute
    raise error_to_reraise
  File "/usr/lib/python3/dist-packages/compose/parallel.py", line 210, in producer
    result = func(obj)
  File "/usr/lib/python3/dist-packages/compose/project.py", line 548, in do
    return service.execute_convergence_plan(
  File "/usr/lib/python3/dist-packages/compose/service.py", line 567, in execute_convergence_plan
    return self._execute_convergence_start(
  File "/usr/lib/python3/dist-packages/compose/service.py", line 506, in _execute_convergence_start
    _, errors = parallel_execute(
    result = func(obj)
  File "/usr/lib/python3/dist-packages/compose/service.py", line 508, in <lambda>
    lambda c: self.start_container_if_stopped(c, attach_logs=not detached, quiet=True),
  File "/usr/lib/python3/dist-packages/compose/service.py", line 620, in start_container_if_stopped
    return self.start_container(container)
  File "/usr/lib/python3/dist-packages/compose/service.py", line 627, in start_container
    if "driver failed programming external connectivity" in ex.explanation:
TypeError: a bytes-like object is required, not 'str'
I dunno what to make of it but wanted to copy paste it quickly.
From what you’ve posted, it seems like the issue might be related to port usage. A similar error has been discussed in this GitHub issue, where it turned out that a port being used by the failing container was still occupied on the host machine.
I’d suggest checking the ports defined for storj14007 in your docker-compose.yml file and ensuring they are free on your host. You can use a command like netstat -tuln or lsof -i to check if the ports are in use. If they are, stopping the conflicting process or assigning a different port in your stack might resolve the problem.
Let us know how it goes, and keep us posted if you need further help! You’ve got this! :blush:
Accordingly the issue posted by @edo
this error is a result of a missing destination port.
The example:
    ports:
      - "28972:28967/tcp"
      - "28972:28967/udp"
      - "127.0.0.1:14005:14002"
But to be sure it would be better, if you could post your docker-compose.yaml here between two new lines with three backticks like this:
    ports:
      - "28972:28967/tcp"
      - "28972:28967/udp"
      - "14005:14002"
then it would be pretty formatted in the post. You may mask any personal information.
Thank you gentlemen, false alarm apparently.
Netstat and lsof didn’t show anything.
Looks like the underlying hard disk for the node was having a problem.
Powering down, jiggling the power cable, and rebooting the server fixed it.
Here was the docker port setup for that node btw, nothing fancy.
    ports:
      - "28971:28967/udp"
      - "28971:28967/tcp"
      - "14007:14002"
