Since some days the online percentage is going down. No changes in the pc or network and in two different nodes in different places. One of them has now 90% the other 98%. The errors are :
If you want to know, when your node was not available, you can use these scripts:
Regarding how to fix - check your router (for example - reboot it at first), if offline events disappear or reduce - then you know what to blame.
If it’s not - then it perhaps your ISP. You can be sure only after setup of port monitoring.
Regarding satellites you can see the status there:
