Online score just drop down…how to get 100% again?
ping
0% losses
…so how?
This shows not “all” network traffic is being blocked. Now you need to find out what the satellite thinks is wrong.
For us1 on the storagenode browse to http://localhost:14002/api/sno/satellite/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S
For saltlake on the storagenode browse to http://localhost:14002/api/sno/satellite/1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE
Paste both results for review.
this for us1
this for saltlake…
Ok these are quite simple as the node is so new.
There are 4 audit windows on us1:
{"windowStart":"2021-08-10T12:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
{"windowStart":"2021-08-11T12:00:00Z","totalCount":1,"onlineCount":0} = 0% uptime
{"windowStart":"2021-08-12T00:00:00Z","totalCount":1,"onlineCount":0} = 0% uptime
{"windowStart":"2021-08-14T00:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
and more on saltlake:
{"windowStart":"2021-08-06T00:00:00Z","totalCount":2,"onlineCount":2} = 100% uptime
{"windowStart":"2021-08-07T00:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
{"windowStart":"2021-08-07T12:00:00Z","totalCount":1,"on1ineCount":1} = 100% uptime
{"windowStart":"2021-08-08T00:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
{"windowStart":"2021-08-08T12:00:00Z","totalCount":2,"onlineCount":2} = 100% uptime
{"windowStart":"2021-08-09T00:00:00Z","totalCount":2,"onlineCount":2} = 100% uptime
{"windowStart":"2021-08-09T12:00:00Z","totalCount":4,"onlineCount":4} = 100% uptime
{"windowStart":"2021-08-10T12:00:00Z","totalCount":3,"onlineCount":3} = 100% uptime
{"windowStart":"2021-08-11T00:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
{"windowStart":"2021-08-11T12:00:00Z","totalCount":3,"onlineCount":0} = 0% uptime
{"windowStart":"2021-08-12T00:00:00Z","totalCount":2,"on1ineCount":1} = 50% uptime
{"windowStart":"2021-08-12T12:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
{"windowStart":"2021-08-13T00:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
{"window5tart":"2021-08-13T12:00:00Z","totalCount":3,"onlineCount":3} = 100% uptime
{"windowStart":"2021-08-14T12:00:00Z","totalCount":1,"onlineCount":1} = 100% uptime
Both point to downtime between 2021-08-11T11:00:00Z and 2021-08-12T11:00:00Z. Since that time window there have been no missed audits so your node should recover.
If you still wanted to look into this further you should check your node logs between those times and the likelihood is that there are almost no log entries, compared to other times. Further pointing toward the node being offline.
tq so much for assistance @Stob
so…i just do nothing n wait for online recovery right?
You can try to figure out - why it was offline to possible avoid such situation in the future.
But regarding online score - it should recover in the next 30 days online. Keep in mind - each downtime extends required time to another 30 days.
orait…i will keep that in mind… :+1:
Does uptime and downtime take into account downtime due to applying OS patches?
Hello @cryptodev1 ,
The online score is affected when the satellite is coming to audit the node, but the node is not responding. Such audit considered as offline.
So, if your node is unavailable from outside, it’s considered as offline.
@Alexey
hello…can u help me read this?
{“id”:“12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”,“storageDaily”:[{“atRestTotal”:51149135059.536934,“intervalStart”:“2021-09-01T00:00:00Z”},{“atRestTotal”:39826098123.56431,“intervalStart”:“2021-09-02T00:00:00Z”},{“atRestTotal”:54285675395.30856,“intervalStart”:“2021-09-03T00:00:00Z”},{“atRestTotal”:45166968824.969826,“intervalStart”:“2021-09-04T00:00:00Z”},{“atRestTotal”:54599238297.75856,“intervalStart”:“2021-09-05T00:00:00Z”},{“atRestTotal”:57259585341.727684,“intervalStart”:“2021-09-06T00:00:00Z”},{“atRestTotal”:52683771280.31406,“intervalStart”:“2021-09-07T00:00:00Z”},{“atRestTotal”:51581820562.94405,“intervalStart”:“2021-09-08T00:00:00Z”},{“atRestTotal”:25575786014.85818,“intervalStart”:“2021-09-09T00:00:00Z”}],“bandwidthDaily”:[{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:57878016,“usage”:2009344},“delete”:0,“intervalStart”:“2021-09-01T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:86412288,“usage”:0},“delete”:0,“intervalStart”:“2021-09-02T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:62172672,“usage”:665856},“delete”:0,“intervalStart”:“2021-09-03T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:65769216,“usage”:0},“delete”:0,“intervalStart”:“2021-09-04T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:36440064,“usage”:354560},“delete”:0,“intervalStart”:“2021-09-05T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:77976576,“usage”:4779264},“delete”:0,“intervalStart”:“2021-09-06T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:68097792,“usage”:354560},“delete”:0,“intervalStart”:“2021-09-07T00:00:00Z”},{“egress”:{“repair”:0,“audit”:256,“usage”:311296},“ingress”:{“repair”:74974464,“usage”:1287424},“delete”:0,“intervalStart”:“2021-09-08T00:00:00Z”},{“egress”:{“repair”:0,“audit”:0,“usage”:0},“ingress”:{“repair”:32242944,“usage”:0},“delete”:0,“intervalStart”:“2021-09-09T00:00:00Z”}],“storageSummary”:432128078900.9821,“bandwidthSummary”:571726592,“egressSummary”:311552,“ingressSummary”:571415040,“currentStorageUsed”:2421694464,“audits”:{“auditScore”:1,“suspensionScore”:1,“onlineScore”:0.8333333333333334,“satelliteName”:“europe-north-1.tardigrade.io:7777”},“auditHistory”:{“score”:0.8333333333333334,“windows”:[{“windowStart”:“2021-08-11T00:00:00Z”,“totalCount”:1,“onlineCount”:1},{“windowStart”:“2021-08-14T00:00:00Z”,“totalCount”:1,“onlineCount”:1},{“windowStart”:“2021-08-16T12:00:00Z”,“totalCount”:1,“onlineCount”:1},{“windowStart”:“2021-08-21T00:00:00Z”,“totalCount”:1,“onlineCount”:1},{“windowStart”:“2021-08-27T12:00:00Z”,“totalCount”:1,“onlineCount”:1},{“windowStart”:“2021-09-05T00:00:00Z”,“totalCount”:1,“onlineCount”:0},{“windowStart”:“2021-09-08T12:00:00Z”,“totalCount”:1,“onlineCount”:1}]},“priceModel”:{“EgressBandwidth”:2000,“RepairBandwidth”:1000,“AuditBandwidth”:1000,“DiskSpace”:150},“nodeJoinedAt”:“2021-08-03T13:31:21.076925Z”}
my online score for europe-north-1.tardigrade.io:7777 just drop down suddenly…
This is the relevant section. It shows that an audit was attempted between 2021-09-04T23:00:00Z → 2021-09-05T10:59:00Z but your node didn’t reply.
Looking closer you can see 5 successful audits and 1 failed audit, so your online percentage would be 5/6 = 83.33333334% which should match the dashboard.
Nothing to do but keep the node online, unless there are errors in the log.
@Stob
my node always online 24/7…how?
My previous reply still applies:
I would recommend to setup uptimerobot.com to check your port. You can see when your port was not available.
I am also getting this although my service and internet is up nearly 100% in the last month
Please check your logs.
Its named storagenode.log
and
How big is the Logfile?
any fatal errors?
Also set your node to the used space setting to avoid further filling the drive.
Is the node monitored by uptimerobot and set to restart after failure in a to short timeperiod?
Your node was not available for a certain amount of time accordingly your online score. You may check when your node was not available and compare with logs of your protection software/hardware (firewall, antivirus, etc.):
windowStart          totalCount onlineCount
2024-03-15T00:00:00Z          2           0
2024-03-15T12:00:00Z          4           3
2024-03-16T00:00:00Z          2           1
2024-03-16T12:00:00Z          2           0
2024-03-17T00:00:00Z          5           4
2024-03-17T12:00:00Z          5           2
2024-03-18T00:00:00Z          2           1
2024-03-18T12:00:00Z          2           1
2024-03-19T00:00:00Z          2           0
2024-03-19T12:00:00Z          3           2
2024-03-20T00:00:00Z          4           0
2024-03-20T12:00:00Z         13          11
2024-03-22T00:00:00Z        742         741
        windowStart          totalCount onlineCount        -----------          ---------- -----------        2024-03-23T12:00:00Z       1097        1061
2024-03-24T12:00:00Z       1105        1093
2024-03-28T00:00:00Z       1266        1265
2024-03-28T12:00:00Z       1346        1340
121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6
2024-03-01T00:00:00Z         56          46
2024-03-02T00:00:00Z         27          26
2024-03-02T12:00:00Z          9           4
2024-03-03T00:00:00Z         18          10
2024-03-03T12:00:00Z          2           0
2024-03-04T00:00:00Z          2           0
2024-03-04T12:00:00Z         16          15
2024-03-05T00:00:00Z         86          29
2024-03-05T12:00:00Z         70          61
2024-03-06T00:00:00Z         30          14
2024-03-06T12:00:00Z          1           0
2024-03-07T00:00:00Z          2           0
2024-03-07T12:00:00Z          2           0
2024-03-08T00:00:00Z         12          11
2024-03-08T12:00:00Z         63          62
2024-03-09T00:00:00Z         11          10
2024-03-09T12:00:00Z          2           0
2024-03-10T00:00:00Z          2           0
2024-03-10T12:00:00Z         13          12
2024-03-11T00:00:00Z          6           5
2024-03-11T12:00:00Z          2           0
2024-03-12T00:00:00Z          2           0
2024-03-12T12:00:00Z          2           0
2024-03-13T00:00:00Z          2           1
2024-03-13T12:00:00Z          2           1
2024-03-14T00:00:00Z          2           0
2024-03-15T12:00:00Z          3           2
2024-03-16T00:00:00Z          2           0
2024-03-16T12:00:00Z          2           1
2024-03-17T00:00:00Z          2           0
2024-03-17T12:00:00Z         37          29
2024-03-18T12:00:00Z          1           0
2024-03-19T00:00:00Z          8           7
2024-03-19T12:00:00Z          5           4
2024-03-20T00:00:00Z          2           0
2024-03-20T12:00:00Z          2           0
2024-03-21T12:00:00Z       1451        1450
2024-03-22T12:00:00Z       1529        1528
2024-03-23T12:00:00Z       1603        1570
2024-03-24T00:00:00Z       1843        1842
2024-03-24T12:00:00Z       1719        1693
        windowStart          totalCount onlineCount        -----------          ---------- -----------        2024-03-25T12:00:00Z       1859        1858
2024-03-27T00:00:00Z       1868        1867
2024-03-28T00:00:00Z       1834        1833
2024-03-28T12:00:00Z       2007        2006
2024-02-28T00:00:00Z         28          23
2024-02-29T12:00:00Z         26          14
2024-03-01T00:00:00Z         61          58
2024-03-01T12:00:00Z        173         146
2024-03-02T00:00:00Z          9           8
2024-03-02T12:00:00Z          2           0
2024-03-03T00:00:00Z        253          80
2024-03-03T12:00:00Z          4           0
2024-03-04T00:00:00Z        264          77
2024-03-04T12:00:00Z          2           0
2024-03-05T00:00:00Z        986         176
2024-03-05T12:00:00Z         49          36
2024-03-06T00:00:00Z          2           0
2024-03-06T12:00:00Z          9           8
2024-03-08T00:00:00Z        374         146
2024-03-08T12:00:00Z        110          46
2024-03-09T00:00:00Z          2           0
2024-03-10T00:00:00Z          4           0
2024-03-10T12:00:00Z          4           0
2024-03-11T00:00:00Z        226         169
2024-03-12T00:00:00Z         80          79
2024-03-12T12:00:00Z        198          83
2024-03-13T00:00:00Z        290          97
2024-03-13T12:00:00Z        119          61
2024-03-14T00:00:00Z         19          18
2024-03-14T12:00:00Z          7           6
2024-03-15T00:00:00Z         19          17
2024-03-15T12:00:00Z         73          34
2024-03-16T00:00:00Z          8           0
2024-03-16T12:00:00Z          8           0
2024-03-17T00:00:00Z          8           0
2024-03-17T12:00:00Z          8           0
2024-03-18T00:00:00Z          8           0
2024-03-18T12:00:00Z          8           0
2024-03-19T12:00:00Z          2           0
2024-03-20T00:00:00Z          5           4
2024-03-21T00:00:00Z        251         250
2024-03-23T12:00:00Z       1579        1536
2024-03-24T12:00:00Z       1567        1549
        windowStart          totalCount onlineCount        -----------          ---------- -----------        2024-03-25T12:00:00Z       1518        1517
2024-03-26T12:00:00Z       1798        1797
2024-03-27T00:00:00Z       1692        1689
2024-03-28T12:00:00Z       1650        1649
12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
2024-02-28T00:00:00Z         58          56
2024-03-01T12:00:00Z          2           1
2024-03-02T00:00:00Z          9           7
2024-03-02T12:00:00Z         29          27
2024-03-03T00:00:00Z         10           9
2024-03-04T00:00:00Z        263          47
2024-03-05T00:00:00Z          2           0
2024-03-06T00:00:00Z         22          21
2024-03-06T12:00:00Z         12          11
2024-03-07T12:00:00Z         77          13
2024-03-08T12:00:00Z          4           3
2024-03-09T00:00:00Z         10           9
2024-03-09T12:00:00Z        278          69
2024-03-10T00:00:00Z        136          57
2024-03-10T12:00:00Z          6           0
2024-03-11T00:00:00Z          6           0
2024-03-11T12:00:00Z         46          43
2024-03-13T00:00:00Z          2           0
2024-03-13T12:00:00Z          2           0
2024-03-14T00:00:00Z         25          24
2024-03-15T00:00:00Z         77          51
2024-03-15T12:00:00Z        230          38
2024-03-17T00:00:00Z          7           5
2024-03-17T12:00:00Z         20          18
2024-03-18T00:00:00Z          6           0
2024-03-18T12:00:00Z         75          72
2024-03-19T00:00:00Z          8           6
2024-03-20T00:00:00Z         34          31
2024-03-20T12:00:00Z          6           0
2024-03-22T00:00:00Z       2016        2015
2024-03-23T12:00:00Z       3309        3201
2024-03-24T00:00:00Z       3451        3450
2024-03-24T12:00:00Z       3282        3249
2024-03-25T12:00:00Z       3278        3277
2024-03-26T00:00:00Z       3065        3064
2024-03-27T00:00:00Z       3404        3400
2024-03-27T12:00:00Z       3225        3223
2024-03-28T12:00:00Z       3790        3782
I use zabbix for monitoring my infrastructure. Don’t have SLA setup on that server. I’ll get it set up. But storj service was up 99.5+ percent of the time the last 30 days. Only change was removing the old satellites which removed ~200GB of data. Couldn’t include all due to char limit.
