Does anyone knows what fiber optic routers can you use to replace the chinese ones from ISP?
Dosen’t need to offer Wifi or portforward, because I already use my own routers. I just need it to:
- be available to the public;
- support at least 1Gbps up and 1Gbps down traffic for the optical port.
- better hardware to handle a huge number of connections (Storj usecase with TCP fastopen);
- offer at least 1 Gigabit LAN port (RJ-45), 1 TV cable port and 1 phone line port (RJ-11);
- support putting it in bridge mode.
I searched for the ISP offered ones and they seem to not be available in shops or even on the official website.
The only models that I found are from Ubiquiti, but I never heard of them and those models don’t offer phone and TV ports.
Are there more standards that they have to meet/ be compatible with, or is just an universal one?
How exactely are they called? Optic fiber routers? Modems? ONT?!
When I search for “optic fiber router”, I only get results with review/add sites recommending top routers from Asus and Co. that can offer super wifi speeds that I don’t need, and none of them have optic ports.
