I sometimes got corrupted pieces when using old 1TB disks, due to media errors.
I thought of an option to saves pieces with built in erasure coding…I assume this would be fairly simple for storj devs?
I guess this goes hand in hand with my optional scrub idea
Edit: Apparently some people call this “local parity erasure coding”
If your block device corrupts data, you have far bigger problems than just trying to make file contents more recoverable. If your file system’s metadata gets corrupted, then you might be easily losing everything on that drive.
Besides, erasure coding makes sense only if the erasure stripes are stored in blocks whose failures are independent (or as close to as possible). So you want either a proper parity RAID (for which the storage node has no business interfacing with) so that stripes are on distinct devices, or at least spread the stripes across the drive (which can also be done by RAIDing partition devices). No need to involve storage node code.
Well, the idea is nice, but I don’t think there is any disk that is theoretically reliable enough to survive, yet causes enough bitrot for your node to be disqualified. Either that HDD is going to be completely gone soon anyway or your node will survive just fine if you just accept that your audit score will drop a little from time to time.
This is how you make devs your enemy
Edit: Actually, let me add some more information for this case specifically. All the erasure coding and decoding takes place either on the client side or satellite side in case of repair. The storagenode side is intentionally left as simple as possible so it can run on super low powered hardware. It doesn’t ever do erasure coding, so this would be entirely new to the storagenode component. Furthermore, it would have a significant impact on hardware requirements (mostly CPU) and adding it as an option would significantly increase the different types of regression testing required and different kind of hardware to optimize for depending on settings.
I also think that this may be something you could solve on the file system level independent from Storj.
I’m not on the Storj dev team, so I won’t speak for them. But I’m betting you would get a similar response from them. Simple is never as simple as you think.
Not sure if mdraid is capable of that many stripes. But then it would be quite impractical anyway, needing to read 100 blocks whenever a customer requests even the smallest file.
6/5 would probably work, though, even probably be fast enough for Storj purposes with some tuning.
Actually I have found something called dm-verity that seems to do what I want. It talks about fec with rs(m,n), which sounds like it. If only I could work out what it all means
I didn’t test this and it will require quite a bit of effort to set up. But I like the concept and didn’t find a more fleshed out option for local on disk parity file systems as most erasure coding file systems are built for large network storage. Perhaps worth a look.
