Hey fellas,
For the past 2-3 weeks (or maybe even a month, I’m not sure), I’ve been seeing this issue:
Here is the result from
df -h
/dev/sda1 2.7T 2.6T 33G 99% /mnt/storj
Now i have been using the same disk for all two years i am running my node.
SO i also have the same space.
I am a simple human.
I thought this would go away after a while but it doesn’t seem like it.
Now i wouldn’t bother you if it was only this but i also noticed that my node is overheating like a toaster.
Then i opened the CPU usage and 75% of it was on the containerd.sock
Now i looked this up on a docker forum and it made thinks a lot better.
Basically i removed the corrupt log files from docker (no idea how this was done but).
Now the load is smaller but still a lot more than usual and the temperature isn’t going down.
Used to be <40 degrees even in the hottest summers but now it’s 50-60.
Should i check something else?
