Hola a todos.
¿Alguien ya usa oCIS - ownCloud Infinite Scale | ownCloud con storj ?
¿Opiniones ?
Puede utilizar el buscador para encontrar comentarios anteriores sobre el tema ¨owncloud¨ - así va discubrir varios hilos donde se menciona como otros usuarios han usado Storj con owncloud.
Ya lo hice y no hay mucho que aprender.
Generally speaking, wouldn’t it be better if the link opened in another tab?
Personally, I like the links in another tab so I can refer both pages in case I need some earlier reference before clicking the link.
You may submit a PR to fix that (you would need to use a markdown style instead of this one).
Thank you. I learned it can’t be done ![]()
Muchas gracias. Luego comentaré más detalles
No, this behavior is not visitor friendly.
The user has a choice to follow the link in the current tab (Click) or open link in a new tab (Command+Click)
But if your link automatically opens in new tab – there is no way for the user to open in in the current one.
Only insecure web site owners do that, fearing that if the visitor follow the link out they will never return. But visitors are not toddlers, they know what they are doing.
I personally strongly dislike when clicks open new tabs or windows. If I want new window/tab – it must be any my decision, not web site’s. I already have 50 tabs open. I don’t need more.
Now this makes sense.
