Page annoying reload when not inactive
can you remove the annoying page reload when not inactive
i was uploading 4gb of data then it reloads the page to login after 30mins inactive
Thanks for your report! I guess you are uploading your file with the Object Browser of the Satellite Console.
We plan to make this timeout configurable in the future, but such a user configuration is not available now.
In general, for large uploads, we advise using a tool designed for this, like the Uplink CLI, Rclone, Filezilla, or S3 Browser.
A workaround which worked for me…
We have made a github issue to fix this problem asap Satellite UI / Bug / Session should not expire while uploading · Issue #5618 · storj/storj · GitHub
