Pausing During upload via Filezilla Pro
When I try to upload to STORJ using Filezilla pro it keeps pausing every 1-2 seconds. Can someone tell me why this is happening and how to fix it?
Does it pause during upload of your files ?
Hello @thereverendd,
Welcome back!
You can increase the number of parallel transfers to fill gaps while the file is buffering before send.
You may also increase the number of parallel connections in the configuration of the server in your Site Manager.
Do you use a native Storj protocol or Storj S3?
