Hi admins
Wondering if you could let me know if payouts have completed for this month? I see some has been paid last few days from the usual wallet.
Thanks
Hi admins
Thanks
The payout is happening in the first two weeks of every month. The current payout cycle is not finished yet.
When it would be finished, it will be published on the forum, in the Node Operators category with payouts and storagenode tags.
You may also check your dashboard - Payout Information - Payout History, when there you would see a November 2024, then the payout is done.
By the way, my nodes can see a payout in the Payout History, so the payout should be completed by now.
I would check with the team.
The payouts are made in 2 waves from what I’ve seen. Maybe 3? In most cases, I’ve been payed in the first wave, but I ended up in the second wave in some occasions. Waves can be a few days appart. The best image you can get from storjnet.info website.
I also haven’t received my payment on Binance yet. It’s been on the 3rd or 4th day of every month for the past year. However, the November payments are already visible on the dashboards of my Storj nodes.
I haven’t received it yet either. In my situation, it seems that the payment for L1 is slightly delayed compared to when using ERA. ![]()
If you see a non-zero Undistributed payout, then it wasn’t sent.
I received the L1 payment. I don’t use L2 address since 2 years ago. As I said… 2 waves.
Also you should check on your exchange what’s the minimum deposit allowed. And if they changed your deposit address.
Or some malware/hacker changed your address in the storagenode. Compare the dashboard with the exchange address from time to time.
Two days ago it was zero, this should be the payment of November
I also haven’t recieved november’s paymet to my L1 wallet. Keep waiting.
As I only reached $35 this month, I won’t be paid out for L1
Interesting, I got a payout at 43 and change on l1
StorJ dropped almost 20% over the last few days - it’s possible that the StorJ amount i similar, but converted to USD value at another time ![]()
