--operator.wallet-features=zksync
I think the tokens were settled this month.
I’m using zkSync, but the deposit hasn’t been made yet.
Is it because I can’t use the storage token as a fee in the zkSync wallet?
The payout is happening in the first two weeks of every month, if your node is eligible to receive it (it’s cleared a Minimum Payout Threshold on the selected network).
The payout for the current period is not finished yet, you will see an announcement here: Search results for 'tags:storagenode,payouts @jtolio order:latest' - Storj Community Forum (official)
I will have to refer to the link carefully. Thank you! ![]()
There is another way to see, that the payout is finished - see the Payout Info → Payout History on your dashboard or the Undistributed payout in case if it was not eligible.
Yes. If the node was not able to clear a Minimum Payout Threshold. But I guess there should not be a minus and zero ![]()
Thank you Alexey, I will wait! ![]()
