Well it was fun while it lasted.
A reboot of my machine, and my node took suicide.
The file is there, and the drive works as normal. Did it kill it self?
2022-05-08T09:49:52.357+0200 FATAL Unrecoverable error {“error”: “Error starting master database on storagenode: database: piece_expiration couldn’t be read (“E:\\Storjdata\\piece_expiration.db”): CreateFile E:\Storjdata\piece_expiration.db: Filen eller mappen er skadet og kan ikke leses.\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:303\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:281\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:248\n\tmain.cmdRun:193\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”, “errorVerbose”: “Error starting master database on storagenode: database: piece_expiration couldn’t be read (“E:\\Storjdata\\piece_expiration.db”): CreateFile E:\Storjdata\piece_expiration.db: Filen eller mappen er skadet og kan ikke leses.\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:303\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:281\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:248\n\tmain.cmdRun:193\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n\tmain.cmdRun:195\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
