Hi I wanted to know if this is normal. I keep getting this piece deleter error. I have connected a PI4 and 2 HDDs via usb. Otherwise everything is normal
Can you confirm your Storj Node is operating normally?
I’m not too familiar with the Storj-Exporter, but I think maybe @greener might have an idea of what is happening here?
Also some others in this thread my have some familiarity with the tool:
Yes the Node is normal in function
Please post a full text of the error from your logs
I dont know how i can used the grep command
docker logs storagenode 2>&1 | grep -i error | grep "piecedeleter could not" | tail
docker logs storagenode 2>&1 | grep -i error | grep "pieces:trash emptying" | tail
2022-12-25T05:30:05.815Z ERROR piecedeleter could not send delete piece to trash {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "ST455RK47GD3D5Y6MLMKUB6DWFGQQXKHDH52ALYBECT7PXIK5TRQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:102\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:245\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Trash:290\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:369\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2022-12-25T05:30:05.817Z ERROR piecedeleter could not send delete piece to trash {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Piece ID": "ST455RK47GD3D5Y6MLMKUB6DWFGQQXKHDH52ALYBECT7PXIK5TRQ", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storage/filestore.(*blobStore).Stat:102\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:245\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).Trash:290\n\tstorj.io/storj/storagenode/pieces.(*Store).Trash:369\n\tstorj.io/storj/storagenode/pieces.(*Deleter).deleteOrTrash:185\n\tstorj.io/storj/storagenode/pieces.(*Deleter).work:135\n\tstorj.io/storj/storagenode/pieces.(*Deleter).Run.func1:72\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
