Yes, you are right. You doesn’t have a public IP on 3g/4g, you always behind the provider’s NAT.
I didn’t meet any exception so far. So the solution would be to use a VPN service with port forwarding feature.
However, you can easily check do you have a public IP or not. Navigate to the Status page and scroll to 3G/4G, write down IP from there, then compare it with IP there: Open Port Check Tool - Test Port Forwarding on Your Router
If they match then your port forwarding will work.
Wow thanks alot. I will use a VPN i think. i just ordered a 3g/4g router that allows VPN.
