Hi everyone, I’m trying to get my first node running but I am having problems setting up port forwarding. My main question is: do I need port forwarding for nodes connected to routers via ethernet?
I am pretty sure the answer is yes, but maybe some background would help explain the question: I have my computer running Manjaro Linux connected to my router via ethernet. When I log in to the router page, I can’t just add a rule like it mentions in the start-up port forwarding documentation. It only gives me the option of setting up port forwarding to devices that are connected wirelessly, not hard-wired. Therefore, since my computer is hard-wired in, I don’t have the option of setting up port forwarding. My ISP is Spectrum, if that helps at all.
Anyway, thanks for any help/advice you might have.
