Hello Sirs,
I am trying to repair bandwidth.db by commaтв on screen below, but it doesn’t work, cursor is just blinking without action. What can be a problem?
Regards,
Alexander
Hello Sirs,
Regards,
Alexander
The command cp should be executed before you started an sqlite3.exe binary, not after.
The sqlite3 binary should be executed with the full path to the database file by the way.
Like
cp E:\StorjD1.14\storage\bandwidth.db E:\StorjD1.14\storage\bandwidth.db.bak
& c:\sqlite\sqlite3.exe E:\StorjD1.14\storage\bandwidth.db
Are you sure, that you have bandwidth.db corrupted? In the article it’s just an example, you need to fix the corrupted database, not always bandwidth.db (your node have 14 databases).
Also, are you sure that your databases are in the E:\StorjD1.14\storage\ folder? This path is usually exist only on docker nodes.
I was thinking what yes, becouse in logs were mistake …bandwidth.db… malformed. But now then I am checking the logs, it is this:
Node is offline. What this message means and what shall I do to repair node? I have 2 nodes on same machine with this mistake, third working well. There are 3 different internet lines with different IP on this PC, but looks it have no influence when I change IP’s between nodes.
I tryed to search on forum, but didn’t found something close to my case. What do you think?
Regards,
Alexander
If this database is reported as a malformed, yes, you can try to fix it with that article.
You also have an option to re-create it:
But you will lose the stat and the history.
“Invalid hostname” is a usual error when the DNS server doesn’t work. Try to use 8.8.8.8 or 1.1.1.1, if they are not blocked by Roscompozor…
Алексей добрый день,
Так и не понял, что была за ошибка с доступам с серверу, но она сама исчезла.
Я пересоздал базы данных, на одном из дисков это помогло и он работает.
На втором, теперь при запуске в логах вижу такую ошибку. Поиск по ней тоже не очень помог. Диск размером 20Тб (18.1), пробовал при запуске выставлять 10Тб, но это не помогло. Что можно сделать?
2024-01-20T13:21:18Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker subprocess started {"process": "storagenode", "satelliteID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker subprocess exited with status {"process": "storagenode", "satelliteID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "status": -1, "error": "signal: killed"}
2024-01-20T13:21:19Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: signal: killed", "errorVerbose": "lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:83\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:717\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", "satelliteID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo"}
2024-01-20T13:21:19Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"process": "storagenode", "satelliteID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "error": "context canceled"}
2024-01-20T13:21:19Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:71\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:717\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-01-20T13:21:19Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "error": "context canceled"}
2024-01-20T13:21:19Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:71\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:717\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-01-20T13:21:19Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
2024-01-20T13:21:19Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:71\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:717\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-01-20T13:21:19Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
2024-01-20T13:21:19Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:71\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:717\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-01-20T13:21:19Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-01-20T13:21:19Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-01-20T13:21:19Z ERROR pieces failed to lazywalk space used by satellite {"process": "storagenode", "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:71\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:105\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:717\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-01-20T13:21:19Z ERROR piecestore:cache error getting current used space: {"process": "storagenode", "error": "filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled", "errorVerbose": "group:\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}```
Regards,
Alexander
диск медленно отвечает. Кроме как выключить Lazy, других рекомендаций нет.
The disk is slow, so I can recommend only to disable a lazy filewalker, to allow it to run with a normal priority. Perhaps it could help.
Do you mean to add extra row in config like this?
Regards,
Alexander
Yes, but you need to uncomment it (remove the # character with a following space, the option should start from the first position in the line) before saving the config and restarting the node.
The value for it to disable a lazy filewalker should be false
I did like this:
And now again this mistake appeared:
This is very strange, becouse neighbour node on same external IP works fine. Only forvarded port is different. You said, I need to use dns 1.1.1.1 or 8.8.8.8, is it in router settings? Do you mean this one?
If so - no effect
Regards,
Alexander
Regards,
Alexander
This error is not related to the filewalker, it’s related to a DNS server - your host cannot resolve the standard hosts. I would recommend to use 8.8.8.8 or 1.1.1.1 as a DNS server on this host to fix this issue.
There to put what DNS?
вс, 21 янв. 2024 г., 15:15 Alexey via Storj Community Forum (official) <storj@literatehosting.com>:
Either directly in the configuration for your connection (network adapter, IPv4) or on your router in the DHCP section.
Алексей, это не DNS. Я попробовал запустить ноду с двумя разными провайдерами. На каждом из этих провайдорав есть другие ноды, которые нормально работают без каких-либо манипуляций с DNS. Я просто подставлял настройки от работающей ноды в эту, но результат везде та-же ошибка. Что еще может быть не так? Жалко из-за этого убивать 3Тб ноду.
DNS тоже подставлял в роутер (видно на скрине в сообщении выше), это не дает результата.
С уважением,
Александр
Тогда что-то (кто-то…) блокирует нормальное подключение к version.storj.io
Ошибка говорит о том, что узел не может подключиться к https://version.storj.io из-за ошибки TLS - может быть что-то пытается подменить сертификат и в результате возникает ошибка, похожая на ошибку разрешения адреса через DNS.
Попробуйте использовать другого провайдера или VPN.
Something is blocking the normal connection to the version.storj.io site. The error is that it can’t establish a secure connection to that site. Looks like something is trying to alter a certificate and as a result it get an error similar to inability to resolve the hostname.
I would recommend to change the ISP provider or use a VPN in case if they are trying to alter a certificate.
Is it only me have such problem? No other claims from Russian SNO? This trick with DNS doesn’t help. No connection via 3 different providers. Nodes which has been started some time ago, continue to work, but if I restart any of them, it give this TLS mistake.
So far - yes. Perhaps your ISP is doing something weird.
You may try to stop and remove the container, remove the image, pull it back, then try to run a node, there is a small probability that you have an old image with outdated certificates chains.
Well, I fixed this TLS error, some strange mistake inside MGTS, was fixed only after changing of router by them and remaking contract from MGTS to MTS.
I add filewalker command to config
but node didn’t become working and still give mistake:
C:\Users\ASKUE-PC>docker logs --tail 50 storagenodeD1.14
2024-01-23T18:50:18Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-01-23T18:50:18Z ERROR nodestats:cache Get pricing-model/join date failed {"process": "storagenode", "error": "context canceled"}
2024-01-23T18:50:18Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:18Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-01-23T18:50:18Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:18Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-01-23T18:50:18Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:18Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-01-23T18:50:18Z ERROR version failed to get process version info {"process": "storagenode", "error": "version checker client: Get \"https://version.storj.io\": context canceled", "errorVerbose": "version checker client: Get \"https://version.storj.io\": context canceled\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tstorj.io/storj/private/version/checker.(*Client).Process:108\n\tstorj.io/storj/private/version/checker.(*Service).checkVersion:101\n\tstorj.io/storj/private/version/checker.(*Service).CheckVersion:75\n\tstorj.io/storj/storagenode/version.(*Chore).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/version.(*Chore).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2024-01-23T18:50:18Z ERROR pieces:trash emptying trash failed {"process": "storagenode", "error": "pieces error: filestore error: context canceled", "errorVerbose": "pieces error: filestore error: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).EmptyTrash:176\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:316\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:416\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:83\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2024-01-23T18:50:18Z ERROR piecestore:cache error getting current used space: {"process": "storagenode", "error": "filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled", "errorVerbose": "group:\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
Error: piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory
2024-01-23 18:50:19,698 INFO exited: storagenode (exit status 1; not expected)
2024-01-23 18:50:19,700 INFO spawned: 'storagenode' with pid 41
2024-01-23 18:50:19,700 WARN received SIGQUIT indicating exit request
2024-01-23 18:50:19,704 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2024-01-23T18:50:19Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2024-01-23 18:50:19,706 INFO stopped: storagenode-updater (exit status 0)
2024-01-23T18:50:19Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2024-01-23T18:50:19Z INFO Anonymized tracing enabled {"process": "storagenode"}
2024-01-23T18:50:19Z INFO Operator email {"process": "storagenode", "Address": "7437493@gmail.com"}
2024-01-23T18:50:19Z INFO Operator wallet {"process": "storagenode", "Address": "0x8675290882f594227d9b69d1fc434bf54b2b5e6f"}
2024-01-23T18:50:20Z INFO server kernel support for tcp fast open unknown {"process": "storagenode"}
2024-01-23T18:50:20Z INFO Telemetry enabled {"process": "storagenode", "instance ID": "12k2GmwPdGt9ryU9ifTwkDN9rkf6wFhqDuAXyiCGJJDRhsjEMt4"}
2024-01-23T18:50:20Z INFO Event collection enabled {"process": "storagenode", "instance ID": "12k2GmwPdGt9ryU9ifTwkDN9rkf6wFhqDuAXyiCGJJDRhsjEMt4"}
2024-01-23T18:50:21Z INFO db.migration Database Version {"process": "storagenode", "version": 54}
2024-01-23T18:50:21Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"process": "storagenode"}
2024-01-23T18:50:22Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"process": "storagenode"}
2024-01-23T18:50:22Z INFO bandwidth Performing bandwidth usage rollups {"process": "storagenode"}
2024-01-23T18:50:22Z INFO Node 12k2GmwPdGt9ryU9ifTwkDN9rkf6wFhqDuAXyiCGJJDRhsjEMt4 started {"process": "storagenode"}
2024-01-23T18:50:22Z INFO Public server started on [::]:28967 {"process": "storagenode"}
2024-01-23T18:50:22Z INFO Private server started on 127.0.0.1:7778 {"process": "storagenode"}
2024-01-23T18:50:22Z INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details. {"process": "storagenode"}
2024-01-23T18:50:22Z INFO trust Scheduling next refresh {"process": "storagenode", "after": "4h44m8.556374383s"}
2024-01-23T18:50:22Z INFO pieces:trash emptying trash started {"process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-01-23T18:50:22Z WARN piecestore:monitor Disk space is less than requested. Allocated space is {"process": "storagenode", "bytes": 16193446518784}
2024-01-23T18:50:22Z ERROR services unexpected shutdown of a runner {"process": "storagenode", "name": "piecestore:monitor", "error": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:158\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:141\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2024-01-23 18:50:22,713 INFO waiting for storagenode, processes-exit-eventlistener to die
2024-01-23T18:50:22Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 104.199.30.73:7777: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 104.199.30.73:7777: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:22Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-01-23T18:50:22Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.94.153.46:7777: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.94.153.46:7777: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:22Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-01-23T18:50:22Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.80.215.116:7777: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.80.215.116:7777: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:22Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-01-23T18:50:22Z ERROR contact:service ping satellite failed {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.172.100.72:7777: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp 34.172.100.72:7777: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-01-23T18:50:22Z INFO contact:service context cancelled {"process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-01-23T18:50:22Z ERROR nodestats:cache Get pricing-model/join date failed {"process": "storagenode", "error": "context canceled"}
2024-01-23T18:50:22Z ERROR version failed to get process version info {"process": "storagenode", "error": "version checker client: Get \"https://version.storj.io\": context canceled", "errorVerbose": "version checker client: Get \"https://version.storj.io\": context canceled\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tstorj.io/storj/private/version/checker.(*Client).Process:108\n\tstorj.io/storj/private/version/checker.(*Service).checkVersion:101\n\tstorj.io/storj/private/version/checker.(*Service).CheckVersion:75\n\tstorj.io/storj/storagenode/version.(*Chore).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/version.(*Chore).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2024-01-23T18:50:22Z ERROR pieces:trash emptying trash failed {"process": "storagenode", "error": "pieces error: filestore error: context canceled", "errorVerbose": "pieces error: filestore error: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).EmptyTrash:176\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:316\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:416\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:83\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2024-01-23T18:50:22Z ERROR piecestore:cache error getting current used space: {"process": "storagenode", "error": "filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled", "errorVerbose": "group:\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
Is it regarding filewalker or wrong connection setup?
It shall not be a connection, becouse port forwarded
Firewall rule activated
New-NetFirewallRule -DisplayName "Storj v3 UDP" -Direction Inbound -Protocol UDP -LocalPort 28975 -Action allow
Command I start the node looks fine
docker run -d --restart unless-stopped --stop-timeout 300 -p 192.168.0.40:28975:28967/tcp -p 192.168.0.40:28975:28967/udp -p 127.0.0.1:14004:14002 -e WALLET="0x8675290882f594227d9b69d1fc434bf54b2b5e6f" -e EMAIL="7437493@gmail.com" -e ADDRESS="77.220.141.15:28975" -e STORAGE="18.5TB" --mount type=bind,source="E:\Identity\storagenode D1.14",destination=/app/identity --mount type=bind,source="E:\StorjD1.14",destination=/app/config --name storagenodeD1.14 storjlabs/storagenode:latest
Alexey, do you think what can it be?
Regards,
Alexander
This is now related to your data location. Please check that your disk is correct and mounted to the system
ls E:\StorjD1.14
It missing the file, which is usually created when you setup the node and if it’s disappeared - something bad is happened: either you lost data, or provided a wrong path.
