Primera vez instalando nodo
Es la primer vez que configuro un nodo y espere mas de media hora pero solo marca offline y CUIC Misconfigured
realice cambio a ddns y ahora el STATUS es Offline y QUIC se queda Refreshing durante horas pero si yo actualizo aparece de nuevo como CUIC Misconfigured, alguien tiene alguna idea?
  • Check that you have public IP
  • Check that you use reliable DDNS and it points to your public address (don’t use duckdns or asus)
  • Check port forwarding to the correct host
  • Check and disable any security solutions, both on the host and gateway.
The effects shall be immediate, there is no need to wait for half an hour. Moreover, if the node does not connect immediately — shut it down and troubleshoot. If you keep it running satellites will reduce frequency of checks and attempts to talk to your node.
