I have run the Storage node for around 1 week untill an electricity cutoff occured and restarted the pc and the router. It is important to mention that I am running the node through Windows 10, using NoIP DNS provieder, since my ip is dynamic. I have checked the port, it is still open after the cutout. The ip in the router changed, but so did in the NoIP DUC windows app, but the node appears to be offline. I have also restarted the docker app, but nothing happens. I think the problem is related to the NoIP app settings, but I cannot locate it.
I did that, it is 192.168.1.xx:28967 , while running noip service and the node went back offline. Tried restarting the storagenode service as well, still nothing.
if you have static external ip, then you not need ddns, if you have dydnamic external ip need to use ddns name, and install duc program from ddns provider, that it will renew it automaticly, also free ddns need to be renewd every month. Yes this is ok farm.ddns.net:28967
yo also can download my toolbox,
install to pc with node, and you can do lot of stuff there, new even basic trobleshooting.
succesrate but it only for GUI Node
