Hello,
I have follow all the procedure but it doesn’t work; can you help me?
Here my logs:
{“level”:“info”,“timestamp”:“1584260713194”,“message”:“Log file created.”}
{“level”:“warn”,“message”:“your address is public and traversal strategies are disabled”,“timestamp”:“2020-03-15T08:25:16.314Z”}
{“level”:“info”,“message”:“node created with nodeID 03996e9ad56740368012bba97471ac1de2df2c75”,“timestamp”:“2020-03-15T08:25:16.361Z”}
{“level”:“info”,“message”:“clock is synchronized with ntp, delta: -307 ms”,“timestamp”:“2020-03-15T08:25:16.392Z”}
{“level”:“info”,“message”:“resolving contacts from https://api.storj.io”,“timestamp”:“2020-03-15T08:25:16.392Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:25:37.420Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:26:07.401Z”}
{“level”:“info”,“message”:“resolving contacts from https://api.storj.io”,“timestamp”:“2020-03-15T08:26:34.528Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:26:37.423Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:27:07.431Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:27:37.468Z”}
{“level”:“info”,“message”:“resolving contacts from https://api.storj.io”,“timestamp”:“2020-03-15T08:27:52.578Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:28:07.447Z”}
{“level”:“error”,“message”:“Unable to connect to bridge: https://api.storj.io, reason: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:28:37.453Z”}
{“level”:“error”,“message”:“Failed to discover seeds from bridge: connect ETIMEDOUT 35.239.195.103:443”,“timestamp”:“2020-03-15T08:29:05.629Z”}
Thanks in advance.
