Hello, my VPN server restarted and I had to configure it again, the problem is that now I cannot connect correctly, I have the error that appears below.
The service turns on fine, I have access to port 28967 from the internet (try to test port 80 using httpd, everything works ok)
When I ping from my VPN client, the IP 146.148.29.23 does not respond, but from the VPN server it does respond, what could be happening?
2020-09-05T04:53:53.450Z ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite error: rpccompat: dial tcp 146.148.29.23:7777: i/o timeout”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 146.148.29.23:7777: i/o timeout\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-05T04:54:04.648Z ERROR nodestats:cache Get pricing-model/join date failed {“error”: “heldamount service error: unable to connect to the satellite 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs: rpccompat: context deadline exceeded”, “errorVerbose”: “heldamount service error: unable to connect to the satellite 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs: rpccompat: context deadline exceeded\n\tstorj.io/storj/storagenode/heldamount.(*Endpoint).dial:229\n\tstorj.io/storj/storagenode/heldamount.(*Endpoint).GetAllPaystubs:105\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:80\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:259\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:79\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-05T04:54:14.451Z ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 2, “error”: “ping satellite error: rpccompat: context deadline exceeded”, “errorVerbose”: “ping satellite error: rpccompat: context deadline exceeded\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-05T04:54:36.452Z ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 3, “error”: “ping satellite error: rpccompat: context deadline exceeded”, “errorVerbose”: “ping satellite error: rpccompat: context deadline exceeded\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-05T04:55:00.452Z ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 4, “error”: “ping satellite error: rpccompat: context deadline exceeded”, “errorVerbose”: “ping satellite error: rpccompat: context deadline exceeded\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
