Problem with my config
not sure what happen but after a edit there should not have done anything (storage2.piece-scan-on-startup: true) harmful it will not don’t start it keep rebooting and don’t give a log too my log file have copy some really fast before it close have try copy the standard and make a new but the same
if I remove the config it start but don’t have the right ports and there for say malfunction .
# how frequently bandwidth usage rollups are calculated
# bandwidth.interval: 1h0m0s
# how frequently expired pieces are collected
# collector.interval: 1h0m0s
# use color in user interface
# color: false
# server address of the api gateway and frontend app
console.address: 0.0.0.0:14002
# path to static resources
# console.static-dir: ""
# the public address of the node, useful for nodes behind NAT
contact.external-address: xxx:28967
# how frequently the node contact chore should run
# contact.interval: 1h0m0s
# protobuf serialized signed node tags in hex (base64) format
# contact.tags: ""
# Maximum Database Connection Lifetime, -1ns means the stdlib default
# db.conn_max_lifetime: 30m0s
# Maximum Amount of Idle Database connections, -1 means the stdlib default
# db.max_idle_conns: 1
# Maximum Amount of Open Database connections, -1 means the stdlib default
# db.max_open_conns: 5
# address to listen on for debug endpoints
# debug.addr: 127.0.0.1:0
# If set, a path to write a process trace SVG to
# debug.trace-out: ""
# open config in default editor
# edit-conf: false
# in-memory buffer for uploads
# filestore.write-buffer-size: 128.0 KiB
# how often to run the chore to check for satellites for the node to forget
# forget-satellite.chore-interval: 1m0s
# number of workers to handle forget satellite
# forget-satellite.num-workers: 1
# how often to run the chore to check for satellites for the node to exit.
# graceful-exit.chore-interval: 1m0s
# the minimum acceptable bytes that an exiting node can transfer per second to the new node
# graceful-exit.min-bytes-per-second: 5.00 KB
# the minimum duration for downloading a piece from storage nodes before timing out
# graceful-exit.min-download-timeout: 2m0s
# number of concurrent transfers per graceful exit worker
# graceful-exit.num-concurrent-transfers: 5
# number of workers to handle satellite exits
# graceful-exit.num-workers: 4
# Enable additional details about the satellite connections via the HTTP healthcheck.
healthcheck.details: false
# Provide health endpoint (including suspension/audit failures) on main public port, but HTTP protocol.
healthcheck.enabled: true
# path to the certificate chain for this identity
identity.cert-path: identity/identity.cert
# path to the private key for this identity
identity.key-path: identity/identity.key
# if true, log function filename and line number
# log.caller: false
# custom level overrides for specific loggers in the format NAME1=ERROR,NAME2=WARN,... Only level increment is supported, and only for selected loggers!
# log.custom-level: ""
# if true, set logging to development mode
# log.development: false
# configures log encoding. can either be 'console', 'json', 'pretty', or 'gcloudlogging'.
# log.encoding: ""
# the minimum log level to log
log.level: info
# can be stdout, stderr, or a filename
# log.output: stderr
# if true, log stack traces
# log.stack: false
# address(es) to send telemetry to (comma-separated)
# metrics.addr: collectora.storj.io:9000
# application name for telemetry identification. Ignored for certain applications.
# metrics.app: storagenode
# application suffix. Ignored for certain applications.
# metrics.app-suffix: -release
# address(es) to send telemetry to (comma-separated IP:port or complex BQ definition, like bigquery:app=...,project=...,dataset=..., depends on the config/usage)
# metrics.event-addr: eventkitd.datasci.storj.io:9002
# size of the internal eventkit queue for UDP sending
# metrics.event-queue: 10000
# instance id prefix
# metrics.instance-prefix: ""
# how frequently to send up telemetry. Ignored for certain applications.
# metrics.interval: 1m0s
# maximum duration to wait before requesting data
# nodestats.max-sleep: 5m0s
# how often to sync reputation
# nodestats.reputation-sync: 4h0m0s
# how often to sync storage
# nodestats.storage-sync: 12h0m0s
# operator email address
operator.email: xxx
# operator wallet address
operator.wallet: xxx
# operator wallet features
operator.wallet-features: zksync
# move pieces to trash upon deletion. Warning: if set to false, you risk disqualification for failed audits if a satellite database is restored from backup.
# pieces.delete-to-trash: true
# run garbage collection and used-space calculation filewalkers as a separate subprocess with lower IO priority
# pieces.enable-lazy-filewalker: true
# file preallocated for uploading
# pieces.write-prealloc-size: 4.0 MiB
# whether or not preflight check for database is enabled.
# preflight.database-check: true
# whether or not preflight check for local system clock is enabled on the satellite side. When disabling this feature, your storagenode may not setup correctly.
# preflight.local-time-check: true
# path to the cache directory for retain requests.
# retain.cache-path: config/retain
# how many concurrent retain requests can be processed at the same time.
# retain.concurrency: 5
# allows for small differences in the satellite and storagenode clocks
# retain.max-time-skew: 72h0m0s
# allows configuration to enable, disable, or test retain requests from the satellite. Options: (disabled/enabled/debug)
# retain.status: enabled
# public address to listen on
server.address: :28967
# whether to debounce incoming messages
# server.debouncing-enabled: true
# if true, client leaves may contain the most recent certificate revocation for the current certificate
# server.extensions.revocation: true
# if true, client leaves must contain a valid "signed certificate extension" (NB: verified against certs in the peer ca whitelist; i.e. if true, a whitelist must be provided)
# server.extensions.whitelist-signed-leaf: false
# path to the CA cert whitelist (peer identities must be signed by one these to be verified). this will override the default peer whitelist
# server.peer-ca-whitelist-path: ""
# identity version(s) the server will be allowed to talk to
# server.peer-id-versions: latest
# private address to listen on
server.private-address: 127.0.0.1:7778
# url for revocation database (e.g. bolt://some.db OR redis://127.0.0.1:6378?db=2&password=abc123)
# server.revocation-dburl: bolt://config/revocations.db
# enable support for tcp fast open
# server.tcp-fast-open: true
# the size of the tcp fast open queue
# server.tcp-fast-open-queue: 256
# if true, uses peer ca whitelist checking
# server.use-peer-ca-whitelist: true
# total allocated bandwidth in bytes (deprecated)
storage.allocated-bandwidth: 0 B
# total allocated disk space in bytes
storage.allocated-disk-space: 13.00 TB
# how frequently Kademlia bucket should be refreshed with node stats
# storage.k-bucket-refresh-interval: 1h0m0s
# path to store data in
# storage.path: config/storage
# a comma-separated list of approved satellite node urls (unused)
# storage.whitelisted-satellites: ""
# how often the space used cache is synced to persistent storage
# storage2.cache-sync-interval: 1h0m0s
# directory to store databases. if empty, uses data path
 storage2.database-dir: "dbs"
# size of the piece delete queue
# storage2.delete-queue-size: 10000
# how many piece delete workers
# storage2.delete-workers: 1
# how many workers to use to check if satellite pieces exists
# storage2.exists-check-workers: 5
# how soon before expiration date should things be considered expired
# storage2.expiration-grace-period: 48h0m0s
# how many concurrent requests are allowed, before uploads are rejected. 0 represents unlimited.
# storage2.max-concurrent-requests: 0
# amount of memory allowed for used serials store - once surpassed, serials will be dropped at random
# storage2.max-used-serials-size: 1.00 MB
# a client upload speed should not be lower than MinUploadSpeed in bytes-per-second (E.g: 1Mb), otherwise, it will be flagged as slow-connection and potentially be closed
# storage2.min-upload-speed: 0 B
# if the portion defined by the total number of alive connection per MaxConcurrentRequest reaches this threshold, a slow upload client will no longer be monitored and flagged
# storage2.min-upload-speed-congestion-threshold: 0.8
# if MinUploadSpeed is configured, after a period of time after the client initiated the upload, the server will flag unusually slow upload client
# storage2.min-upload-speed-grace-duration: 10s
# storage2.monitor.interval: 1h0m0s
# how much bandwidth a node at minimum has to advertise (deprecated)
# storage2.monitor.minimum-bandwidth: 0 B
# how much disk space a node at minimum has to advertise
# storage2.monitor.minimum-disk-space: 500.00 GB
# how frequently to verify the location and readability of the storage directory
# storage2.monitor.verify-dir-readable-interval: 1m0s
# how long to wait for a storage directory readability verification to complete
# storage2.monitor.verify-dir-readable-timeout: 1m0s
# if the storage directory verification check fails, log a warning instead of killing the node
# storage2.monitor.verify-dir-warn-only: false
# how frequently to verify writability of storage directory
# storage2.monitor.verify-dir-writable-interval: 5m0s
# how long to wait for a storage directory writability verification to complete
# storage2.monitor.verify-dir-writable-timeout: 1m0s
# how long after OrderLimit creation date are OrderLimits no longer accepted
# storage2.order-limit-grace-period: 1h0m0s
# length of time to archive orders before deletion
# storage2.orders.archive-ttl: 168h0m0s
# duration between archive cleanups
# storage2.orders.cleanup-interval: 5m0s
# maximum duration to wait before trying to send orders
# storage2.orders.max-sleep: 30s
# path to store order limit files in
# storage2.orders.path: config/orders
# timeout for dialing satellite during sending orders
# storage2.orders.sender-dial-timeout: 1m0s
# duration between sending
# storage2.orders.sender-interval: 1h0m0s
# timeout for sending
# storage2.orders.sender-timeout: 1h0m0s
# if set to true, all pieces disk usage is recalculated on startup
# storage2.piece-scan-on-startup: true
# storage2.retain-time-buffer: 48h0m0s
# how long to spend waiting for a stream operation before canceling
# storage2.stream-operation-timeout: 30m0s
# file path where trust lists should be cached
# storage2.trust.cache-path: config/trust-cache.json
# list of trust exclusions
# storage2.trust.exclusions: ""
# how often the trust pool should be refreshed
# storage2.trust.refresh-interval: 6h0m0s
# list of trust sources
# storage2.trust.sources: https://www.storj.io/dcs-satellites
# address for jaeger agent
# tracing.agent-addr: agent.tracing.datasci.storj.io:5775
# application name for tracing identification
# tracing.app: storagenode
# tracing.app-suffix: -release
# buffer size for collector batch packet size
# tracing.buffer-size: 0
# whether tracing collector is enabled
# tracing.enabled: true
# how frequently to flush traces to tracing agent
# tracing.interval: 0s
# buffer size for collector queue size
# tracing.queue-size: 0
# how frequent to sample traces
# tracing.sample: 0
# Interval to check the version
# version.check-interval: 15m0s
# Request timeout for version checks
# version.request-timeout: 1m0s
# Define the run mode for the version checker. Options (once,periodic,disable)
# version.run-mode: periodic
# server address to check its version against
version.server-address: https://version.storj.io
log.output: "/app/config/node.log"
my original
# color: false
console.address: :14002
# expose control panel
# debug.control: false
# edit-conf: false
# log.caller: false
# log.encoding: ""
 log.level: info
# log.stack: false
metrics.app-suffix: -alpha
metrics.interval: 30m0s
operator.email: xxx
storage.allocated-disk-space: 10.00 TB
# storage2.database-dir: ""
# tracing.sample: 0
Remove the # at the start of that line and make sure there is no space at the start too. Then start your node.
here the excess space before the option, please remove this space character. Each option must start with the first position in the line.
thx for the help fond this one also think perhaps that was the one . it run now thx one more
Using a coder oriented editor gives you a colorful image of the parameters; you can easily spot what is wrong. Usualy extraspaces or the # from the begining are the problems.
