Hey, so I noticed some problem recently with my nodes. I think it started happening with .80 versions. I have a few nodes and whenever they restart or update. The values reset. Used storage,trash etc.
Here is screenshot from before restart. It runned for almost 30hours.
The values in the Total Disk Space graph are basically resetting every time to the same values. 8.01TB Used storage, 58GB trash etc.
Every reset they go back to 8.01 on this node.
I noticed it happens on pretty much all nodes after reset. These values reset to specific point in time and for other node it goes back to 6.01TB value.
I’m not really sure what is happening here. The rest of the values are progressing fine. Only these values in that ‘Total Disk Space’ Graph/section are looping to the same value.
This is mean that a filewalker cannot finish the scan. If you disabled it, you need to enable it back.
Please also check your disk for errors and your databases
I didn’t disable filewalker. And I don’t see any errors in my log regarding malformed database…
Also I don’t think all my nodes can have corrupted database… one node maybe yes, but this is happening on all nodes.
These are from 1-2 days ago. I counted 3 sats here. One ID repeats 3 times.
And when I grep filewalker I get these errors that u can see on the screenshot in the first post. Just at different times.
Here is screenshot
Ok so I found something weird.
2 days ago I created a new node, and the same thing happens there… it has 80GB data and when I restarted the node today, it went back to 77GB…
No, from the errors it looks like your disk is not keep up with requests and it cannot finish calculation of used space.
How is you disk connected to this device? What’s filesystem?
Nothing strange, some data likely got deleted (moved to the trash).
disk is in USB tower connected via cable to the machine, filesystem is ext4. Node is via docker.
How can I be sure filewalker is done ? When I see retain logs from all satelittes? This error for calculating used space is done by filewalker on start of the node, then there is no more logs of that.
Yes, it’s working only on start. It also refresh the cache every hour. If it would not finish the calculation, I would suggest to check your disk for errors, make sure that your USB disk has an external power supply and restart the node.
You probably kill the filewalker with the restarts. First screen ist right before the shutdown. (Update)
Probably right before here, too.
With 8 TB it will very likely need to run more than 30 hours. If you kill the process it resets to last known values and start over next time till it can finish and saves new values.
I don’t know exactly there are save points between satellites or not but during the process I think there are not.
