Problem with Storj mobile app
Hi, I don’t see the folders created in my bucket in the mobile app when logging in with the grant access.
Hi @epsilonzeio
This is almost always due to a mismatch between the encryption passphrase/access grant/credential being used. Uploaded files/folders are only visible when the same encryption passphrase is used in all locations.
many many thanks! It’s been solved
But unfortunately the app is not working on all devices…
could you please tell which device is working the best or if it depends on the android version
Hello @epsilonzeio,
We do not have a mobile application, but our customers can create such an app. I would suggest to contact authors of your application.
thanks Alexay, I fixed the issue…
