hello and sorry if the issue has allready been resloved when i try to install stroogenode.msi everything work fine but then the installation process stop and a message appear : there is a problem with the windows installation package a program as part of the setup did not finish install and then the install rool back
do you how i can fix the issue
thanks
Hello @festos67,
Please show 20 last lines from your logs: How do I check my logs? - Storj
