Hola tengo un problema con el nodo, no me cuenta el trafico
necesito ayuda
gracias
Alexey
November 7, 2020, 6:37pm
2
Hola @drahcir
Bienvenido al foro!
Parece que su nodo tiene muchos pedidos sin enviar en la carpeta orders/unsent.
Los pedidos no enviados son vÔlidos solo 48 horas después de su creación. Si no ha enviado pedidos desde octubre, este es el motivo.
En el caso de la versión de la GUI de Windows, se colocan en "C:\Program Files\Storj\Storage Node\orders\unsent"
En el caso de la ventana acoplable, se colocan en la ubicación de almacenamiento.
Por favor, utilice estas instrucciones para solucionar el problema de pedidos no enviados atascados:
Stop the storagenode
Remove all orders older than 48 hours (they will not be accepted because they expired already)
Move all remaining orders to the other folder
Move orders by batches back to the orders/unsent
Restart the storagenode
If orders are sent, repeat from p.4
if orders are stuck, move half to the other folder and repeat from p.5
Repeat p.7 until you will have a broken order - please remove it.
Repeat from p.4 until all orders are sent or removed.
Then please remove orders from the oā¦
AdemĆ”s, me gustarĆa pedirle que mire ese hilo:
We noticed 2 mistakes in October payout. The conversion rate was off by 10% and some storage node didnāt submit all orders. Our first priority is now to fix both bugs as quickly as possible. Second priority is to regain trust. It is too early to promise anything. For now letās say we will evaluate how we can correct the payouts as good as possible. Because fixing the bugs has the highest priority it might take a few days before we look into correcting the payout.
