Hi,
after a connection failure i have a problem.
I had to restart the system and have just little traffic.
The system only ran for about 1.5 months.
All satellites show 100.
Engress: 150-200mb
Ingress : 0mb
Hi,
Engress: 150-200mb
Ingress : 0mb
well docker got updated 6 days ago, + a week so 13 days looks about right.
you are most likely running an old storagenode version, you should update it asap.
thanks!!! upgraded and it works instandly
Please, setup an automatic updates: Software Updates - Node Operator
