I was starting my identity storage…
But the result…
I tried many times… ![]()
Can you help me? What I need to do?
Check out the result here below ![]()
pi@raspberrypi:~ $ identity create storagenode
Generating key with a minimum a difficulty of 36…
Generated 82467373 keys; best difficulty so far: 38
Found a key with difficulty 38!
Unsigned identity is located in “/home/pi/.local/share/storj/identity/storagenode”
Please move CA key to secure storage - it is only needed for identity management and isn’t needed to run a storage node!
/home/pi/.local/share/storj/identity/storagenode/ca.key
pi@raspberrypi:~ $ identity authorize storagenode myeemail@…
bash: erro de sintaxe próximo ao token inesperado `newline’
pi@raspberrypi:~ $ grep -c BEGIN ~/.local/share/storj/identity/storagenode/ca.cert
1
pi@raspberrypi:~ $ grep -c BEGIN ~/.local/share/storj/identity/storagenode/identity.cert
2
Reddit post: https://www.reddit.com/r/storj/comments/lerz5i/please_help_me_what_i_need_to_do/
Setup:
Raspberry Pi 3 Model B 1GB RAM
External Hard Disk 2TB
