Please check below. I understand that there is an identity added or something. And he can’t overwrite that.
or something
I would like to get my emergency working.
But that’s sweet every time with me.
I’m not very good at headless environment. So I need your help.
How can I get my existing Id here in the raspberry and get the Nood working. I’ve already created an ID elsewhere so I’d like to get that working here in the raspberry.
Hello and welcome to the forums @Handala are you talking about a node I’d ?
Did you make it on PC not pi?
If so did you put it in the correct location
Also if you tried to make an Id on the pi it will still be there i recommend if you currently have no storage node setup
Remove the identity copy again the one from your more powerful Device
You already have an identity there in ~/.local/share/storj/identity/storagenode
You should either remove it or create a new one with a different name, i.e.
identity create storagenode2
Then you would need to use storagenode2 instead of storagenode in following commands (identity authorize storagenode2 your@email:1jnf498tjg49gj...) and path to the identity will be /home/pi/.local/share/storj/identity/storagenode2.
