Hi, I recently mounted a node in docker with prometheus and grafana, the storj node is up but I can’t get prometheus to communicate with storj-exporter which is up on the ip http://0.0.0.0:9651/
I have tried modifying the /prometheus.yml file changing the targets to:
storj-exporter:9651,
127.0.0.1:9651,
0.0.0.0:9651
All of them have given me the same error.
I have also tried to solve it following this tutorial but it keeps showing me the same error.
Storj-exporter is up and showing data:
I also leave a capture of all the containers that I have raised:
Thank you very much in advance.
PS:
Before showing the unknown status in the target menu, it showed me the down status with the following error message:
Get “http://0.0.0.0:9651/metrics”: dial tcp 0.0.0.0:9651: connect: connection refused
When I modified the prometheus.yml file the error message disappeared and the status changed from down to unknown
