Public bucket (Cloudflare integration)
Hi,
I would like to make a bucket to be public, and integrate it with Cloudflare.
I know the cloudflare part, as I have done it with Backblaze and Wasabi in the past, but I cannot find information on how to make a storJ bucket public?
Thanks
Alex
Hello @Slewrate
Welcome to the forum !
This post should help you find what you need.
" Storj-hosted S3 Compatible Gateway - Storj DCS doesn’t support direct publishing. To generate public URL you need to use uplink share command"
Would be a best approach, you can use Cloudflare DNS service to register Storj DCS bucket in your domain and you can also configure CDN and SSL for it.
