Hi Storj team,
I’m trying to better understand the security model behind satellite-managed encryption.
From my understanding, when a project uses a managed passphrase, the satellite stores the passphrase encrypted and can later decrypt it when needed. However, it appears that an authenticated project member can retrieve the decrypted passphrase through the project configuration endpoint:
GET /api/v0/projects/{project-id}/config
If the response contains the plaintext passphrase, then the passphrase is ultimately exposed to the browser for authorized users.
My question is:
Doesn’t returning the decrypted passphrase to the client introduce additional security concerns?
For example, if a browser session is compromised, an XSS vulnerability exists, or someone gains access to the user’s authenticated session, could the managed passphrase be exposed?
How does Storj evaluate and mitigate these risks in the managed encryption model?
Is the expectation that users of managed encryption trust both the satellite and the authenticated browser session, whereas users requiring stronger privacy guarantees should use user-managed encryption instead?
I’m not questioning the design choice itself—I’m trying to understand the intended threat model and the security considerations behind exposing the managed passphrase through the project configuration API.
Thanks!
