To me in the mail, I received a letter from Storj, where they talked about updating, (Node Update Version
v0.28.2) and the link https://github.com/storj/storj/releases/tag/v0.28.2
Is this true or a cheating ?
Storage Node Operators,
Please update your node within the next 72 hours to prevent your node’s reputation from being affected.
Any node that doesn’t update won’t be able to connect to the network. Ahead of our production release, nodes participating won’t be penalized during downtime for network improvements.
Watch your email and follow the Storage Node Operators category in our [community ](information on future releases.
Make sure to [follow the instructions to run a software update immediately]
To get more information about the changes in this update please take a look at the [changelog]
Important note about mounting your node hard drive:
In the early stages of our alpha, we had incorrect instructions for how to mount your node in the Explorer Setup Guide on GitHub. If you’re an affected user, you’ll see -v instead of --mount in your docker run storagenode command to point to the location of their identity and storage folders. Please update your docker run command using these
Storj does send out notifications for important updates like updating your storagenode (SN).
You can check the changelog in the above link to see what changes were made in this update.
If you are running GUI windows then it updates automatically. If its docker then there is watchtower for automatic updates else you might need to manually update.
In the folder C: \ Program Files \ Storj \ Storage Node are the files storagenode-updater, storagenode-updater.old, storagenode.old.v0.26.3, storagenode. So do I need to update manually, or automatically update?
